Nov 26, 2012 22:31:17 GMT
Nov 26, 2012 22:59:59 GMT
have you considered.... getting that sealy spring if it looks the same?
hairymel
avatar by volksangyl
Club RR Member Number: 207
Nov 26, 2012 23:31:29 GMT
Last Edit: Nov 26, 2012 23:34:14 GMT by hairymel
whats that burning smell?
oh curse word :-(
Nov 27, 2012 18:50:46 GMT
It willl only take a couple of minutes to find a spring. Alll of a sudden 30 mintes has gone. LOL yes I have considered using a different one. Just wandered if someone knew a good spring place! Mine definitely has a larger diameter wire in the spring. Also I need to check the inside circle diameter. Jack is in a lockup so will do the measurements and phone around.
hairymel
Nov 27, 2012 20:45:21 GMT
I spent at least 15 of those minutes trying to work out what the blooming thing would be called so i could do a more specific search
oh curse word :-(
Nov 29, 2013 21:59:54 GMT
Its been a year but I found one in Bristol. Attention span of a gnat is my problem. Chance cobnversation in a autoparts. Bloke suggested a garage equipment supplier he knew. Looks identical to the broken one.
groovy
Holy thread resurrection batman! Good to know you finally sorted it mate lol Lee
bortaf
Nov 30, 2013 14:44:35 GMT
I just got a new spring for my 90's sealy, £4.13 from my local car spares shop, picked it up when i collected a new seal kit for my 50 Yr old bradbury 3 ton jack (gets rebuilt every 10 years or so just in case )
R.I.P photobucket
