andyborris
Nov 20, 2012 22:07:49 GMT
The little blue light that tells you the main beams are on, if that's not working (and you rely on oncoming drivers to let you know that you're not dipped) is it a MOT fail?
Changing to a speedo that won't have the blue warning light!
Thanks (and I'm joking about the oncoming drivers!)
RobinJI
Nov 20, 2012 22:13:11 GMT
Yeah it's a fail. Just add a light externally somewhere.
andyborris
Has to be blue?
bl1300
Section 1.7 4 c of the MOT inspection manual says.
Method of Inspection = on vehicles first used on or after 1 april 1986, the "tell tale" illuminates when main beam is selected
The relavent RFR = the tell tail does not illuminate when main beam is selected.
The above is taken straight from the VOSA MOT inspection manual for private passenger and light commercial vehicle testing. Issue date 01 January 2012.
As far as I take that the colour of the light should not matter and if the car was built before 1st of april 1986 one is not required.
Current fleet.
Small blue LED in a hole drilled into somewhere in the dash Nice and discreet, and virtually invisible when off
taurus
I fitted a green one to a car as it was all I had to hand and it went through the MOT no problem.
andyborris
Nov 21, 2012 22:37:12 GMT
Thanks, it's a 1969 car, so not needed.
Andy
