Nov 19, 2012 20:50:38 GMT
I love Sierra's. I love them a lot.I have had many, the last one being a GT, that I sold about a week ago, to Robinxr4i. Reason being I had been made redundant, again, and it had to go. I now have new work, and so with it, a new Sierra. I had spotted this one a good few years ago, and it was on on my 'abandoned cars' list. I did try to buy it then, it wasnt for sale. Fast forward to now, and I get tipped off about a Sierra for sale, scrap money, which might have the same engine as my Estate(imploded en route to Telford one day). When I was told where it was, I knew it was the same. I went to go look at it, knowing I would buy it anyway.I have a good feeling. Anyway, I give you, my new Sierra! ;D Note the amount of leaves! Its a bit battered in places Mainly both wings, the odd door or two! On the move after two and a half years Coming back down And parked, awaiting the recovery truck! I really like that pic, not sure why. Anyway, the plan.Well, I'm afraid my estate may have to wait a little longer for an engine!It may be battered, but its totally solid!Couldnt believe it. Rear door shuts, perfect. Sills, all perfect.Battery tray, perfect. Its amazing!There's no way I can break this thing up. Yes its a bit rough, yes the inside looks like a landfill, and home to much wildlife, but its a survivor, having escaped certain death twice now, as this owner, and the last wanted it for bits, but never got to it. And, it has a full set of uprated springs, and a phat exhaust! More updates to follow after the weekend.
Nov 19, 2012 21:06:21 GMT
Look forward to seeing how this progresses. Something about this makes me really like it despite the dents etc. So much potential.
Nov 19, 2012 21:16:07 GMT
Glad you've got a job sorted! Can't believe you've got another Sierra so quickly, you're a mad man.
MK2VR6
Mk2 Golf GTi 90 Spec
Nov 19, 2012 21:51:47 GMT
Always good when a condemned car is giving a second chance. Go forth and get dent bashing!
Nov 20, 2012 11:11:22 GMT
It's great to see one of those old rep-mobiles being saved from a near certain death...! I still hanker after another Sierra having had one (2.0i GLX estate) many moons ago, I like the look of the later model XR4x4's... Anyhow, this car looks superb and I am sure just a days worth of solid elbow grease will get it looking a million times better...!
***GARAGE CURRENTLY EMPTY***
Leo
Nov 20, 2012 13:49:08 GMT
Yet again RR totally fails to disappoint. What most people would consider more than ready to be thrown away, an RR'er digs out, tows away and gets back on the road (I know, I'm getting ahead of the thread a bit). Nice work!
English bloke living in Amsterdam.
'92 VW Golf 1.8 CL @ 220,000 km and counting...
hamps
www.medwayrscentre.co.uk
Nov 20, 2012 14:35:19 GMT
Can't wait for updates can't beat a sierra Awesome save
Nov 20, 2012 18:56:23 GMT
Cheers all.Never let it be said I'm not a trier! Had a poke around today.Put a battery on it, just to see if it'll turn over.Turned the key, and all I get is a 'click'. Tried a few times, and no more than that.Thought the engine might be seized, so went to have a look, and saw a fair amount of smoke coming from the live battery lead, at the starter motor.The lead was obviously very hot.Any ideas why?Is it, do you think, that I'd been trying the starter quite a bit, and it wasn't turning, that somehow thats overloaded the wiring, causing heat?Or something else? Disconected the battery, just in case, and turned the engine on a ratchet on the bottom pulley, and it turned.So thinking the starter is stuck. Might try and take it off to see if I can un-stick it.
pabblo
Nov 21, 2012 12:55:14 GMT
As others have already said great save with the Sierra. Especially as it had been left for dead and was ment to be broken up for parts. Always liked Sierras though I've never owned one myself but my Grandad had a G reg one new as a company car complete with brick in car telephone! Went 3 times round the clock in it and had 2 replacement gearboxes I seam to recall him saying. Sounds to me like it's the starter motor thats at fault. You could try the old trick of getting a piece of wood and a hammer an giving the casing of the starter motor a tap a few times see if that frees it off? Should then hopefully get it started. Or you could try bump starting it as well if you have the space etc. But the starter motor will want replacing though I should think. Good luck with it and I'll be looking forward to seeing more progress.
speedy88
"Nice Cortina mate"
Club RR Member Number: 118
Nov 21, 2012 20:58:13 GMT
The resistance of the starting circuit is really high which is what is making the wires smoke. Trying it for a while will make it really hot yeah.
It's clicking so relays are engaging - means you're likely to have electrons whizzing around and judging by the smoke, the right amount as well. Like the poster above I agree it's probably a starter issue.
luckygti
I need to try harder!
Nov 21, 2012 22:55:26 GMT
Great save, hopefully it can be resurrected, it looks like it could be a really nice car. As for the starter, stick it in gear, and rock it backwards and forwards. Might work Of course, you probably already tried that if you're a Ford man
Nov 22, 2012 16:45:20 GMT
Cheers all. Ive tried all the normal things, but to no avail.Had another poke around today, and think its properly stuck.Even to the point that when I connected the battery again, I got big sparks, like it was still drawing power.Gave it a whack, re connected battery, no sparks, then a click on the key, smoke, again.Just found another starter in a breakers not too far away, so shall go grab that tommorow or sat if I can. Meanwhile, I attacked the inside. Before; An an hour with the hoover later, Its not perfect, but at least I can sit in it now without being acosted by a critter!Still needs a bit more, but Ill wait till I take the seats out for that.Need a bug bomb too, just in case. Otherwise, I found out that the central locking works, so does both electric windows, and the horn, and the stereo and tape player.The heater fans work too, but wont completely turn off, even when set to zero.Indicators don't, but I'm hoping thats becase the wiper/lights on/off stalk is missing, so not making the circuit(or something). And this is the curse word that came out of it, including what appears to be a TV stand? ???Will investigate later. And lastly, a quick showoff of my beautifully none rusty rear arches! ;D Cant believe it consider its life for the last four years!
Nov 25, 2012 19:15:30 GMT
Small updates, but great news! Yesterday, I went and had another play, and decided to remove the starter, as that seemed to be the issue.And the result was, completely seized solid.I found a breakers yard with another starter, and a quick round trip(well about two hours actually) later, and I have another one, as seen below; Old New With the new one fitted, I gave the key a turn, just to make sure all was good. And then it started to get a bit weird. On the key, it started to fire!It tried to start.But with no plug leads attached!This freaked me out a bit, and went to have a look, and realised that there was one lead still in the distributor. plugged the rest in, and turned the key, and on the key, it bloody started!Just like that.two and a half years of not being started, and it just went.I wasnt even in the car, just stood next to it.I wasn't expecting that, so hadn't put any fuel in it, so was running on years old fuel, and well too.Sounds pretty good! ;D ;D I am happy with this. So anyway, that was yesterday. Today, I put some fresh fuel in, started it again, and prepared for its maiden voyage around the yard.Only to find, that the clutch is stuck.Wont go into gear when running, but engine off,into gear, and it jumps forward even with the pedal in, so think thats the case.Need to figure out how to un-stick. Had another go on the inside instead, Seats out;Messy Major hoover session later I also raided my box of bits, and found a couple of wiper/headlamp stalks, as they're missing from my car.Plugged them in, and that gave me working wiper motors, and lights!They all work, apart from indicators(not sure why yet). Also, a bit weird is putting the wipers on, when the lights are on, and it turns the lights off.Not totally sure the stalks are the right ones, as there is a spade connector that doesn't go anywhere.Might be a reason for the oddities?Hopefully ill figure it out.Cheers for reading!
Nov 25, 2012 20:02:04 GMT
you cant beat journeys like these, booked marked coming on well. i freed a clutch off years ago just by starting it in gear and driving it around our yard, well it worked for me anyway
Nov 25, 2012 20:20:41 GMT
Nov 25, 2012 20:32:23 GMT
I like a good Sierra thread and this is most deffo one.
Will watch with interest on how this progresses
MK4 Ford Escort XR3i - Standard MK6 Ford Escort GTi - Track Car
GaSmOnKeY
I like Rusty old Fords...
Nov 25, 2012 20:39:27 GMT
looking good. id have had that for bits!!
oh and the heater fan.. try adjusting the hot cold slider on the heater control till it goes off. its meant to do that.
1983 Escort rs1600i Van 1984 Sierra 3dr soon to be 24v 1989 2.9 XR4x4 1992 2.9 v6 transit flatbed 1988 Range Rover 3.5 2005 ford Ranger - dead 2003 Mk1 Focus RS 2003 Mk1 Focus RS #2 and a...... Renault trafic sl27 tdci 100 Daily hack.
Nov 25, 2012 20:39:49 GMT
Yay, Sierra love and rescue all in one thread...after a day of issues with my little shed (Sierra) it's nice to read a positive story, makes me feel its all worth while thank you! With regard to the light/wiper issue, mine has always dropped down to side lights when I use the rear wiper, I haven't got a clue what causes it I'm guessing a power drain somewhere. It's never come up at mot time though. Good luck with it I've book marked this for future inspiration when rust gets me down
Copey
Nov 26, 2012 14:03:12 GMT
well saved can't wait to see it progress!
dbdb
Nov 26, 2012 16:11:33 GMT
I'm glad you're saving this Sierra, it takes a certain amount of courage! I've long liked them, possibly because it is one of the first major cars I remember coming out. They were quite bold, at least in styling terms and their look has lasted. I think they'll be quite a classic eventually.
David
