tom13
Nov 14, 2012 12:13:35 GMT
Hi Guys,
After a cheap estate to use as my daily. If its petrol it needs to be under a 1.6 litre, if its a diesel it needs to be under 2litre.
Ideally after something like a cordoba 1.9 diesel or astra 1.7 diesel.
Age does not matter just needs to be reliable.
Thanks in advance.
Tom
keithrg
Dame they destroyed 6 mk1 escorts making Fast and furious 6 :(
Nov 14, 2012 12:40:08 GMT
what would you class as cheap ?
tom13
Nov 14, 2012 22:48:21 GMT
Under 1000pounds. Ideally as cheap as possible.
keithrg
Ive got an ASTRA 1.7 DTI estate 2001 51plate, complete car, Taxed, moted, (Tax is like £125 a year I think Insurance is a group 4 really cheap. Alloys, will need one tyre and a slow punture fixed. Cambelt done, new rear brakes. Selling as It became hard to start, (burned out starter motor), replaced the starter motor and car was still pain in , Found that if I earthed the engine it was fine 20miles later it broke down again. went and bought another one as didnt want to raplace part after part finding issue. Then investigated and found ecu was cause of all problems. This has now been replaced. I'm a just waiting on my mate to reset ecu so we can comfirm everything is 100%. will double check the mot and tax expiry. It owes me £1011. stop starts and drives spot on The wiper park is out of sink, needs contacts cleaned key remotes work intermitantly (worn fobs). usaul slight rust to rear wheel arch got an advisory for oil leak leak on last mot. would be happy to re-mot will get advisories for tyre and oil leak. I reckon its worth £825 all day long, part worn tyre and puncture repair = £25 and a couple of hours you will have a sorted cheap to run motor. Selling this one rather than the replacement as that has a rpm read error which make it hick up 100 yards from cold start and then feels slightly under powered. Have no Idea what the fault is.
tom13
Nov 15, 2012 10:21:59 GMT
OGm
tom13
Nov 15, 2012 10:23:21 GMT
Got any pics, also whats the milage and where are you based?
keithrg
Nov 15, 2012 12:36:59 GMT
basildon essex 205k and they all look the same lol. Ill get a couple and post up later with t&t details
keithrg
Nov 15, 2012 15:34:57 GMT
Last Edit: Nov 15, 2012 15:46:54 GMT by keithrg
tom13
Nov 15, 2012 22:02:05 GMT
Thanks Keith but that's a little high milage for me. Cheers Any more Folks?
Nov 16, 2012 12:15:41 GMT
got a renault laguna sport tourer ! 54 plate , just had void bushes done on rear , 114,000 miles , 2 keys for it , very reliable gives reasonable mpg , (34 ish combined) mot'd and taxed
tom13
Nov 17, 2012 21:20:14 GMT
Thanks Mike but I won't be able to insure that and the MPG is a little low.
Is there anything else out there?
craig1010cc
Club RR Member Number: 35
Nov 18, 2012 19:29:18 GMT
I take it my Audi 80 estate wouldn't be of interest?
tom13
Nov 20, 2012 10:42:22 GMT
Thanks Craig but it's not really what I was after, anything else?
Nov 21, 2012 13:46:43 GMT
Seat Alhambra any good?
