Selling this due to loving my drift Volvo much more.....
1996 328i Coupe
Tax Feb 2013
MOT June 2013
Welder
Vertical OBP hydro with willwood master cylinder
Recent new coilovers
Recent new clutch (with receipt)
Lots of poly bushes
New thermostat and housing
Water pump replaced by previous owner
M50 inlet conversion (not sure its giving the gains it should, but flies once above 3500RPM)
Suede dished wheel & boss
E34 BBS alloys with good tyres
Only had a short time but I've recently spent over £500 on it, (mostly at Chizfab) including:
New radiator
Vanos overhaul
New viscous fan clutch
New cam cover gasket (more expensive than you'd think!)
Plus 2 tyres replaced as they were on the limit when I bought the car
Headunit replaced as the one that came with the car didn't work
Downsides: some typical minor drifty scars, doorcard doesn't fit well and missing some trim, and an oil leak around the base of the dipstick tube where its not sealing too well.
£1200
The car is just south of Glasgow in Rutherglen.
Test drives not possible as I've swapped the insurance on to another car, but it can be started up etc no probs.
Give me a call on 07779 695 234 if you have any questions or to view.
Edit, recent pics added:
1996 328i Coupe
Tax Feb 2013
MOT June 2013
Welder
Lots of poly bushes
New radiator
Vanos overhaul
£1200
