I was going to post this in the show me Sierras thread, but like the low red saff IMO it deserves it's own thread.
Not only does this look killer, but the engine choice is inspired.
Want more boosted Ford and BMW goodness check out - www.skogenracing.com/
A dreadful translation of the spec.....
Rebuilt Växellådstunnel
Moved bulkhead 20cm
ZF box
Sachs 618 pressure plate
Sexpuckars Sinti
Converted to hydraulic clutch
M20 flywheel
M20 starter
Shortshift
shortened växelspakslänkage
Custom Made gear mount
BMW Propshaft with Ford knot
2pcs gimbal
Custom Made växellådsbalk
Relocated front spring towers
Adjustment Plates to change Camber
Removed stabilizer bar
Step uniballs instead stabilizer bar
Wishbones modified for uniballs
Strutbars
Rally Strut front
BMW front brake caliper
Will Wood discs front
Steel braided brake lines
Butt Mare engine mounts
Rebuilt wishbone rear for straightened wheel angles
Rebuilt rear spring tower
Spax coilovers
Shorter drive shafts Ford Granada
Ford Scorpio Diff
Rebuilt diff mount
Sierra 2.9 rear disc brakes
Fuel Cell in trunk
Dual K jet fuel pumps
Coarse fuel lines
rebuilt dashboard
Autometer Tachometer
Autometer Speedometer
Autometer Oil Pressure
Autometer Oil Temp
Autometer Water temp
Autometer Fuel gauge
Autometer Boost
Custom Made heater
engine
BMW M50B25
Garret GT40
Dual intake cams
Refurbished top with mirafrästa seats etc.
New bearings, gaskets, etc.
Toppdeckat blocks
Vanos Pistons
7,20:1 in compression
New circles
Custom Made manifold
60mm Wastegate
3.5 "downpipe
3.5 "exhaust system
V-band clamps
KL Racing intercooler
DO88 Silicon Hose
Samco Silicone hose
Megasquirt V3.0 with additional code
4bars map sensor
Waste Fire coil
Launch, Fan Control, etc.
Custom Made elhärva
630cc injectors
BMC sport filter
Moved bulkhead 20cm
ZF box
Sexpuckars Sinti
M20 flywheel
M20 starter
Shortshift
2pcs gimbal
Strutbars
Rally Strut front
Spax coilovers
Ford Scorpio Diff
Rebuilt diff mount
Fuel Cell in trunk
Coarse fuel lines
rebuilt dashboard
Autometer Oil Temp
Autometer Boost
Custom Made heater
engine
BMW M50B25
Garret GT40
Dual intake cams
Toppdeckat blocks
Vanos Pistons
New circles
60mm Wastegate
3.5 "downpipe
3.5 "exhaust system
V-band clamps
DO88 Silicon Hose
Samco Silicone hose
4bars map sensor
Waste Fire coil
Custom Made elhärva
630cc injectors
BMC sport filter
