Colin
[quote author=damien4884 board=othrmod thread=139253 Anyone know of any coins around the same size as a modern 2p that I could make into a ring for the mrs that won't leave her with black marks (she never listens!!)[/quote]
2p 25.90mm old 5p 23.59mm old 10p 28.50mm
thats the diameter of those, depending if it needs to be smaller or larger you might get away with using one of those
great replacement wedding band!
Dec 13, 2012 15:38:00 GMT
Well, the first draft of the Steampunk hat is done. Opinions please? ?? I have tried not to overdo it, as that is quite easy. Electro Mechanical theme. Biggest problem is that all my rolls of solder wire are resin core so no acid in there, and despite cleaning and sanding the copper plate which came out of an old PC power adaptor, no adhesion.... so onto the hot glue gun and some contact adhesive and old fashioned wire binding. Wrapped up with a note asking forgiveness in case she totally hates it. Also included spare keys to the shed, garage and the alarm codes, so that she can get in there to make it right. Ended up not doing any pics of the make up, but sure you can figure it out. PS: Bugga !!! Just realized the top bits are cammo'd by the grass behind the hat. Too bad, its wrapped up now, so no re-photographing.
Last Edit: Dec 13, 2012 15:56:46 GMT by grizz
Dec 13, 2012 17:26:07 GMT
Sorry, another better pic from my phone.
Dec 13, 2012 19:16:11 GMT
[quote author=damien4884 board=othrmod thread=139253 Anyone know of any coins around the same size as a modern 2p that I could make into a ring for the mrs that won't leave her with black marks (she never listens!!)[/quote] 2p 25.90mm old 5p 23.59mm old 10p 28.50mm thats the diameter of those, depending if it needs to be smaller or larger you might get away with using one of those great replacement wedding band![/quote] I've got a few more coins to have a play with in the past few days and a steel mandrel with ring sizes marked on it. My ring has fallen foul of the sander at work and now has a lovely flat spot on it caused by a whizz from a 100 grit pad might make it a feature!
Last Edit: Dec 13, 2012 19:17:34 GMT by damien4884
1977 datsun 810 180b estate
Dec 13, 2012 19:55:51 GMT
Pinstriped baubles ;D
Dec 14, 2012 11:50:06 GMT
These are awesome! How much for a pair?!!
Dec 14, 2012 12:16:52 GMT
Hi mate, cheers for the comment ;D Doing them at £9 each fully pinstriped or £11 with a name/writing on them plus postage.
Got 2 here ready painted (with space for a name) 1 chrome with blue striping and 1 in satin silver with blue striping if your interested?
Cheers Slacker
bar2
Dec 15, 2012 14:21:53 GMT
Hi all just built this up for my daughter for here Christmas it's a 1984 mini burner
howie
Dec 19, 2012 21:04:42 GMT
At last a thread I can contribute to! I've just finished this for my boy for Christmas. Quick spec - 12v agm battery, bosch wiper motor driving homemade differential via bicycle chain and sprockets, forward and reverse relays selected by indicator stalk, double foot pedals to make it go.
Dec 19, 2012 21:48:58 GMT
That's brill that tractor
1961 FORD POPULAR 100e 2.0 dohc Mk1 2dr Ford cortina
Dec 21, 2012 15:34:23 GMT
+1 that tractor is awesome. heres the ammo box ive put a pc inside.. christmas pressie for my 9 yr old army and gun obsessed boy. its his first pc so its a pretty old but good machine inside. running xp (nice easy os) upgradable but at his age this will do. was annoyed though as orginal motherboard died hence why the cd drive sticks out... the old motherboard was smaller and it sat in flush. hey ho. and a keyboard to match.. did a mouse too but forgot to take pics.
84 mazda 323 gt (twr) b6t engine
85 mazda rx7 s3 12a
90 mazda 323 estate
90 mazda 323 estate (for the mrs ;-) )
Dec 22, 2012 23:08:24 GMT
I love those coin rings, but how do you keep the text on the outside?
I love those coin rings, but how do you keep the text on the outside? Different techniques. Search coin rings on Youtube. Text on outside starts with hole through the middle and then " flipping " the ring to get face side facing outward. Hope that helps.
cavman
feeling inspired :)
It's a bit late, but I only managed to present these the their recipients over new years so didn't really want to post them up in case they got seen! But as I posted earlier I decide to make some staffs for some mates, and here is the finished product: close up of the tops: They certainly took a bit more work than I thought they might, but I'm pleased with how they came out. More importanly my mates loved them too so it's all good! I can post up more details of how I made them if folks would like? but this is a car forum afterall so might not be the place! James
'78 Mk1 Cavalier Coupe - I wish I had a pound for every time someone told me "my dad used to have one of those"!!
It's a bit late, but I only managed to present these the their recipients over new years so didn't really want to post them up in case they got seen! But as I posted earlier I decide to make some staffs for some mates, and here is the finished product: close up of the tops: They certainly took a bit more work than I thought they might, but I'm pleased with how they came out. More importanly my mates loved them too so it's all good! I can post up more details of how I made them if folks would like? but this is a car forum afterall so might not be the place! James Those are really neat. I collect walking sticks (NO IDEA WHY) and those are lovely. I am sure the recipients were very impressed.
Well, I should have known...... Made and gave Nicola the Steampunk hat, then she started to grumble about a hat stand to set it on. Today I made an effort and sorted out some wood and ended up with 3 pieces of Tulip wood. Turned a Base. Head and then the Stem and put them together. Put is out in the lounge with the Tophat on, then waited to see what the boss thought..... Success. Earlier on this morning I also made up some brooches for her. Happy to say they were what seems to be a success as well.
Last Edit: Jan 4, 2013 20:56:25 GMT by grizz
bazzateer
Imping along sans Vogue
Rian,
You're just as good with the intricate/delicate stuff as you are with the big/heavy stuff!
Baz
cavman
feeling inspired :)
Thanks Grizz, from a chap of your talents I take that as quite the compliment! I really enjoyed doing it as it plays to many of my interests, so I may make some more at some point just for fun.
Anglia68
Powered By Boredom.
Hi Grizz, Thanks for the clock case,it should do the job very nicely.
Hi Grizz, Thanks for the clock case,it should do the job very nicely. No probs Pete, glad you could use it. Looking forward to the result.
