My project thread is about a 1991 Peugeot 309 Green. "Green" in France, is a limited series wich included many option : Open roof, power-locked doors, power windows...And green interior The engine is the 1L4 TU3AF with double body carburator, 75hp and it have about 102000km. Let's see it just after I bought it : the interior is not in very good condition Then the work begin... First of all, I take out the TU3 engine with a home made system I remove the silent-bloc then I get a little down the engine like this, the engine + the gearbox can be remove easily easily if you not forget to disconnect the Exhaust manifold Then just have to lift the engine out Put a crick under the car... that is so light right now and can be move easily ;D Remove the Exhaust manifold under the engine Then put the engine on a carriage There's a hole left After a little inspection, there a bit of rust, be nothing to important
First work, the drive shaft... The CV joint must be changed I cleaned it with a metalic brush Paint it in silver hammered effect colour Wing side, I use "universal" CV join that can be cut to right diameter Gear box side, it's specific CV joint, with metalic part You just had to put the different pieces together Mount the wheel side CV joint first Put the tripod and the circlips Don't forget to put the spring change the joint (it's in the CV joint kit) Put the metalic part Old it, the hammer it The drive shaft is finished
I virtualy work on my 309 today, and this what ti looks like...
My new virtual pic test, very... GreenIn the real world, I about the front bearing First, remove the big circlips (seen later on a pics) Then remove the exterior part of the bearing With an extractor, I remove the interior part of the bearing I put the new bearing in the hub I put the big circlips I use a threaded rod to put the hub J'en profitte bien sur pour nettoyer, gratter, brosser...les pièces Then 2 pass of paint
Today, I received this
Nov 11, 2012 17:34:56 GMT
Today I make some work on my 309 (anyway it's raining today :no: ) I don' have a lot of money to put on this project, so I tryed to keep a lot of item With WD40 and petrol, the ball bearing begin to roll Then I put it in oil and whitewashes with grease For the silentbloc I use silicon grease to protect them The metalic spare part are painting Then I have what I need to put my coilover
Last Edit: Nov 11, 2012 17:48:02 GMT by DropForged
Nov 11, 2012 17:37:30 GMT
Then it's no over 2 screw unscrew A pin to remove A patella to remove 2 holder to unscrew The front axle is down I use glass glue to try repair it I'll see if that work...
Last Edit: Nov 11, 2012 17:56:24 GMT by DropForged
micrat
Building a Kanjo styled Cinquecento :)
Excellent work you are very skilled!
Thank's
Mar 16, 2013 16:58:56 GMT
Mar 17, 2013 17:49:43 GMT
I work a little on my 309 this weekend I cleaned up the engine bay There is some rust but not too much paint it will be a good think... Then I remove the wing Wing are screwed Under the hood Under the bumper Rear the wheel arch Then it left one in the interior Wings were stick too The best way is to heat And use hammer and screwdriver Under the wing, evething was removed, make the work easier Then remove the wing slowly to not bend it
dbdb
I like the 309; I am pleased to see there is quite a lot of interest in them now.
You are doing some good work on yours - it will be in fine shape when it is finished.
David
Thank's dbdb Today I clean the engine bay... I use some oven cleaner spray, it worked so great Before Aflter
smellyferret
Back in a retro after 7 years!
Brilliant! Like the hotwheels idea too. Good work!
Loving the details keep up the good work.....
Alex
This car is stereo-typical of why retro riders are so great.....taking a car that someone would scrap....stripping it to a bare shell and turning it into a work of art
Thanks guys Today : homemade engine holder worked so great wtih the rest of my high technical equipment I decide to do a shaved engine bay Put body filler sand down Then put finition body filler and sand down again Sometime it's impossible just to put the bondo So I use bitume and bondo on it
1991 Peugeot 309 Green ChasR
@chasr
Club Retro Rides Member 170
It is good to see that a 309 is being given a bit of TLC. It shall be interesting to see how this pans out .
