hi guys i am building a set of headlights at the moment
and i have a pair of hella AZ91HP projectors
that came out of the hella e36 angel eye headlights in the low beams
question is if i remove the cut off shields inside
can i then use theese as high beam projectors
so efectively both low and high beams will have the same projectors but the high beams will have the cut off shields removed
thanks
dave
thanks
dave
