aws
Just smile and wave boys. Just smile and wave.
Spring is in full glory, so there are lot of events to attend. First one was Youngtimer organised event Car&Coffee. There was some 150 cars in that event. I was too lazy to make a photos, so here are just a few with one car. It was not smooth sailing before the event however. I wanted to tune the engine management system and that was a bit of a challenge. After the heat up car started to hesitate and a loss of power was evident. Almost you can not drive one. So make it short we found out that fuel pump is dying after it gets running for hour or so. Next early morning prior the event I was laying on the ground in order to put spare one on. And it worked. Still needs to be adjusted the fuel trims. It runs too rich, but at least it runs. BR
May 10, 2016 12:32:32 GMT
And then it's finnally finished....
I've just started... hhhhhuuummmm..... restarted mine...
That looks gorgeous...
May 10, 2016 14:01:18 GMT
Great work. You should be very pleased with yourself.
aws
Update. Got my all fleet together. And some troubles. After last time driving now I got an oil pressure lamp lighting up. If I rev engine it disappears. I thought it was due to too rich mixture and that petrol was making oil too thin in oil sump. Since it was running very rich. And oil smelled after petrol as well. So I changed the oil to 10W40 and filter. Started the engine and lamp was not on. .... Until after 5 minutes it went on again. If I increase revs a bit around 1000 rpms, it goes off. So will get a mechanical gauge today from shop to check actual pressure in the system and the will see. Have red in forums that it has been some week spring in oil relieve valve. So thats my hope, since I don't think that gauge is faulty. Of course that would be the easiest solution, but I don't think it will be like that. So thats a story for now. Not very happy.
eurogranada
Good luck on your search, hope it's a small thing!
aws
So update from yesterday. Got an engine support. Tightened the engine to the hoist, so it doesnt fell of. Lifted car up. And unscrewed the 4 bolts that keep cross member to the body and 2 engine mount nuts. Lowered the front axle and I was able to get the oil pan out of the way. Here is the oily chap. Took it off and made it apart. Hoping that it will be ok to change the pressure spring. And nope. It needs a new pump.
At least you've found the problem before any lasting damage. Are pumps easy to get for those?
aws
May 25, 2016 10:03:34 GMT
At least you've found the problem before any lasting damage. Are pumps easy to get for those? You can get those from the shelf as well. Matter of time and money.
May 25, 2016 12:55:26 GMT
Sorry to ear about that. I got a used spare but I never checked yet if it's any good...
I think I saw something on the green books about how to test it but need to recheck...
If you need I'll send you the url for them...
May 26, 2016 21:40:52 GMT
aws
May 31, 2016 17:32:22 GMT
New pump ordered
aws
Pump installed and oil pressure is back. So back on the road.
aws
Things has changed interestingly. Have been contacted with a guy from FB 164 group. Fast Forward and my car has found new home. So I delivered car to Sweden where new owner picked it up. As far I can see he really takes care about it. Export plates On the ferry On the trailer heading to new home. But most likely space can not be empty and will be filled with some old Volvo project. So stay tuned.
Shame to see it go, but I'm already looking forward to seeing what you do next.
Ahh export plates,I will need some soon when I bring a car back from Latvia. How much were they?
aws
Jul 10, 2016 17:03:03 GMT
Ahh export plates,I will need some soon when I bring a car back from Latvia. How much were they? Back from LV? What are you up to? All in all it was something around 70 euros.
Ahh export plates,I will need some soon when I bring a car back from Latvia. How much were they? Back from LV? What are you up to? All in all it was something around 70 euros. Next time I'm over visiting family,I might bring a car back. Uaz 452 would be nice.
