Hi all,
I need to select a high pressure fuel pump and a pressure regulator to use on an upcoming project.
I'll be using injectors from a 1.4 corsa Z14XEP engine, which I believe is about a 20HP per cyl engine.
I need a high pressure pump from a fuel swirl pot and a pressure regulator on the end of the fuel rail. But I do not yet know what fuel pressure rating I should be choosing for the regulator.
The engine is a small capacity, supercharger engine that will be running about 6 or 7psi of boost. Aiming for around 70BHP (but tons of torque hopefully)
Can anyone advise?
Can anyone advise?
