benjy_b
Yorkshire and The Humber
Hey guys,
I require cruise control coding on my mk3 golf tdi.
Anyone in Leeds able to do it for me in exchange for beer tokens?
Regards,
Ben
Last Edit: Oct 11, 2012 10:49:35 GMT by benjy_b
2005 Subaru Forester 2.5XT 1999 BMW E36 318i Touring with OM605 Mercedes Engine 1996 Lada Riva with Honda S2000 Engine
I have a Ross-Tech Vagcom setup on a laptop over in harrogate but i've only recently started to play with it.
Is this a retro fitted setup you need coding or one where you've changed a part and it needs re-coding?
benjy_b
I've fitted an OE cruise control stalk and harness extension.
According to online information, I am required to "switch it on" inside the ecu.
Basically all drive by wire tdis came with cruise control, but most require it activating.
Ahh right, i've done a bit of searching and found the instructions that should turn it on so should be able to help. PM on its way to you.
benjy_b
Oct 11, 2012 10:48:41 GMT
Sorted!
Thanks again David!
No problems, nice to meet you.
