pork
Getting nearer to bolting it together. Need to sort oil feed to turbo. Are kits from t'bay ok? What should I avoid? Where's best place to pick up feed, just tee off pressure switch?
Also, my turbo had ports for water cooling, do I have to pipe these in, or can I blank them off?
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
can blank the water cooling off,.
facebook: rodney dean / rd transport
pork
Are they not needed then?
What about the actual oil feed
feed off the oil pressure switch hole with a t piece bud, water cooled turbos are designed to run water cooling, but i aint on a couple with out a problem, not sure on the long term tho
cars: orion 1600 i ghia mk2 orion 2.2 vtec ghia mk1
pork
That's cool. Ideally I just want to see of I can get it all running correctly, then I suppose I can think about water pipes. Cheers
