I have a complete manual 1980 (early type) 280zx non-targa. Its fairly solid and has had some repairs and now needs only small areas of body sorting. In fact it would almost pass an MOT as is if it were not for the fact that the engine is in bits. It was taken out to do some performance mods, (mostly polishing, porting etc) Possibly has some uprated injectors. everything has been repainted etc. The work was done but engine never got built back up. This is the first 280ZX i've had which I consider the underside solid good enough to be put back on the road-able. If you know how to reassemble an engine, (or put another one in) you could get this back on the road. Comes with keys, docs and even a sales brochure. More info: Five Wolfrace 6 x 14 slots with nearly new set of Enduro 205 70 14 tyres. Polybushed front and rear arms,strutrods,antirollbars etc. Suspension all resprayed etc. NEW brake discs and pads all round. New (pattern) front wings New exhaust system (not fitted) Bad points: had repairs around screen, screen is cracked. Rear arches need attention. Doors repaired poorly (filler in bottom) headlining is missing. (has pop-up glass sunroof) Everything £700 will break it no takers so struts, diff, shafts, gearbox, distributor etc will be for sale. Will O77O2 3486O4
Last Edit: Oct 15, 2012 12:59:12 GMT by datman
nomadx
Hi mate, if you break it i would be interested in the polybushes.
:2003 Clio 172 Cup: - :1992 Fiesta XR2i Trackcar: - :1983 Nissan Datsun 280zx: - :1999 Standard STA:
nomadx
also exhaust and the new brake bits (presuming the exhaust will fit a 2+2)
Last Edit: Oct 6, 2012 21:38:57 GMT by datman
any takers before it gets broken up..
got any pictures of the rotten bits?
let you some later today. Its basically holes in rear arches. There are however repair panels INCLUDED. but you could just fill the holes if you were not going for a full resto. tailgate is mint. Bonnet is good. wings are new (curse word fit) Fuel pump is missing, as far as i know pretty much everything else is there
nomadx
Oct 10, 2012 22:03:09 GMT
still interested in bits as above if you do break mate
Oct 12, 2012 10:40:30 GMT
comes with these repair panels for the back arches!
Last Edit: Oct 13, 2012 0:40:40 GMT by datman
nomadx
Oct 14, 2012 20:28:35 GMT
please break it lol
nomadx
Oct 14, 2012 20:30:16 GMT
Also, what colour is the interior?
Its tan interior. Got someone coming to look re buying it whole later today.
Deposit taken
Delivered to Nottingham
Last Edit: Oct 19, 2012 1:29:56 GMT by datman
