...anyone had/got one fitted?
as fitted to my Acadiane
finally decided i need to get it running again, non starting so pulled ignition apart to check over. got live feeds to coil, condenser & points, weak sparks at plugs when 'tapping' points together, but no spark when cranking.
soooo....possible condenser breakdown? open to more suggestions, however to back to the main Q...
toggle switch is standard up, off, electronic down,self explanatory.
red LED - timing. should this go off/on when altering timing statically?
green LED - should this be on all the while?
got rained off so seeking answers BEFORE i fry it by fiddling with Black Magic
