Sept 19, 2012 19:06:17 GMT
Hi folks Slightly obscure question - I have a Jag Mk2 which has disgraced itself by jamming its starter motor. I need to drag it out of the lock up garage so I can get it fixed. Does anyone know where one can attach a tow rope to the front, as like most old cars there are no towing eyes. Thanks in advance. Cortinaman
Old Fords never die they just go sideways
Sept 19, 2012 20:46:05 GMT
Crossmember/bottom arm thats where I would start
Dave
Sept 21, 2012 22:25:44 GMT
Tricky..... i had to use a solotow on my old 250v8 to avoid damaging the bodywork......can you access the bumper bolts? If you can remove the front bumper, and make a new bumper iron with a tow hook ....
hope this helps......or just get a few mates to help push it?
"No............I think I'll stick with the Maxi"
Arther Daley
How to tow a Jaguar Mk2ChasR
@chasr
Club Retro Rides Member 170
Sept 21, 2012 22:27:24 GMT
I would try the bumper irons but be warned that they may get bent in the process....
Sept 21, 2012 22:46:16 GMT
Thats why id make a new one out of a piece of flat bar
Arther Daley
Sept 21, 2012 22:50:02 GMT
Or over simplify the problem, long long rope, around the rear axle, and under a wooden block under the front sub, then tow as low as possible on the tractor......this should keep the rope from fouling the bodywork
Arther Daley
Sept 24, 2012 12:08:59 GMT
Thanks chaps - in the end I put a strop round the cross member which just cleared the front valance - so no trouble there. I could have done without the dozy woman trying to drive between the jag and the tow vehicle on a roundabout though!
Sept 25, 2012 17:31:28 GMT
Hence why tow ropes are illegal to use on the public highway.....
before some one jumps up and says "well why are they allowed to sell them?", they are only supposed to be for pulling out of ditches etc, not towing a car at 30mph with a 16th of the required stopping distance.
Arther Daley
Sept 25, 2012 19:05:23 GMT
I have to revise my statement........i cant find a "law" for tow ropes, apparently it is at thr disvression of the officer at the time
Arther Daley
