I bought these to try on my T3 - They fitted fine and wound down as low as possible gave about a 80mm drop on a panel van.
They are designed for a T4 but fitted my T3 fine. They were probably a little on the stiff side for a panel van. Used for about 2 weeks/150 miles. I'd recommend using some "lowered" dampers because they dislocated a bit when jacked up, but passed the MOT no worries.
Advertised as 20-90mm drop on a T4 but I don't think there's really enough adjustment in the spring platforms for that - I reckon more like 50-80.
I was hanging on to them to put back on the van one day but I'll never bother.
The springs are 160mm tall.
Adjusters are 55mm ID with grubscrews to secure, and the spring platform jobbie is 72mm ID.
£85 posted.
£85 posted.
