pork
Sept 17, 2012 18:33:09 GMT
Excuse my ignorance, but, What are they What do they do Why would I need either of them Once you know, u know, ay! Thanks Sent from my iPad using ProBoards app
Dez
Club RR Member Number: 34
Megasquirt and megajoltDez
@dez
Club Retro Rides Member 34
Sept 17, 2012 18:39:39 GMT
megasquirt= injection and ignition. gives you a fully mappable ignition and injection system, irrespective of what each part came from. has lots of uses, from eliminating troublesome stock engine management that cant be separated from immobiliser systems on modern engines, to running injection with aftermaket throttle bodies.
megajolt= ignition only. typically used in conjunction with carbs on an engine that has distributorless ignition.
pork
Sept 17, 2012 18:43:00 GMT
Thanks So with the megasquirt, can you plug parts from different vehicles, I.e bike throttle bodies and stuff Sent from my iPad using ProBoards app
Dez
@dez
Sept 17, 2012 18:55:10 GMT
yep, pretty much. its tied into using a few specific components as far as i know, like 36-1 trigger wheels, but aside from that, its pretty adaptable. it is entirely possible to use it to get bike throttle bodes to work on a modern efi engine, providing you can get all the sensors talking to each other. i struggle to get my head round some of it, ive been doing a few megajolt setups to get used to that before i 'move up' to megasquirt, but as far as i understand it, the principles are the same except megasquirt uses a 'proper' ecu to control the sparks, whereas a mejajoint unit basically piggybacks with a ford EDIS unit to control ignition.
pork
Sept 17, 2012 19:07:07 GMT
Ok thanks, il have to do some more reading,
Got any links to any builds that use these?
Sept 17, 2012 20:17:20 GMT
Megasquirt started as a purely fuel injection thing to be used with the sparks provided by the car's existing ignition system. There are several variants of the hardware. The original processor (and standard software) - called an MSI - only does fuel and doesn't do sparks. However, you can use "MS Extra"* code on an MSI processor to do sparks as well. The later processor - MSII - is more powerful and does sparks out-of-the-box. in addition to the different processors, there are a coupe of different circuit boards floating about as well - the V3 is more flexible for modifications than the V2.2, but is a little more expensive (if you can still find a V2.2 - dunno, haven't looked in ages). In order to calculate the amount of fuel required, several sensors are required (air temp, coolant temp, lambda, etc.) - the MS design uses GM sensors as standard, but others can be supported. In fuel-only guise, you connect an input to the ignition coil so it can read the engine's speed. There's a Manifold Absolute Pressure (MAP) sensor built into the MS ECU to detect how much load the engine's under - more load requires more fuel so it doesn't melt at what. When adding spark control as well, you can either use the Ford EDIS (Electronic Distributorless Ignition System) setup - which uses a module and a 36-1 trigger wheel to generate the spark itself but receives a signal from the MS ECU to control the amoutn of advance - or you can run a speed sensor (doesn't have to be 36-1) directly into the MS ECU and use that to control the ignition coil(s) directly. All the fuelling maps etc. are adjustable over a PC-based interface. You'll have to set up the "injection hardware" yourself - that's throttle bodies, manifolds, injectors, fuel pipes, fuel pressure regulators, etc. - but there's plenty of information out there. It's well worth reading the MegaManual from Bowling and Grippo (the originators of the MS) - it goes into great detail about the principles and practicalities of DIY EFI. You can probably skip the "assembly" section until you have it on the bench in front of you though. www.megasquirt.info/The MS Extra site has a lot of information covering different options for reading engine speed and producing sparks - after all, adding ignition control is one of the main reasons it exists: www.msextra.com/doc/index.htmlMegajolt is basically an offshoot project - a stripped-down megasquirt intended to only provide ignition control. It's much less 'open', so there are fewer options: it's designed to be used with the Ford EDIS setup and basically needs a few wires and a bit of pipe to install it - but it can't do fuel. I'm not aware of any projects on here using it yet, but I do have a V2.2 MSI to control the fuel (via Yamaha R6 TBs) and sparks (via EDIS) for the hairy engine I'll be building for my Clan. Eventually. *In years past, the MS Extra code had various silly long names such as "Megasquirt'n'spark Extra." You might still find information under those headings, but TBH all you need to know is in the 2 websites above.
Last Edit: Sept 17, 2012 20:21:08 GMT by jrevillug
Midas
Club RR Member Number: 14
Megasquirt and megajoltMidas
@midas
Club Retro Rides Member 14
Sept 17, 2012 20:26:52 GMT
I run a home soldered MegaJolt on the Midas, as above it only deals with sparks but it does do it very well and has default maps for NA and forced induction. It will take information from either a throttle position sensor or a MAP sensor. Crank position is taken from a 36-1 trigger wheel.
It cost me £120 to get rid of the A series distributor and go to mapped ignition, probably the best thing I ever did.
pork
Sept 17, 2012 20:40:32 GMT
Thanks very much, very useful
Sept 18, 2012 0:41:00 GMT
JaMes beat me to it! It's worth having a look here to see what others have installed megasquirts on... www.msruns.com/index.php
Koos
pork
Sept 18, 2012 6:53:29 GMT
So, if I was to install mega jolt onto my k10 micra (cbr600 bike carbs and turbo) what would I need?
Ford edis4 ..........and,.....?
sowen
Club RR Member Number: 24
Megasquirt and megajoltsowen
@sowen
Club Retro Rides Member 24
Sept 18, 2012 7:23:08 GMT
So, if I was to install mega jolt onto my k10 micra (cbr600 bike carbs and turbo) what would I need? Ford edis4 ..........and,.....? Sent from my iPad using ProBoards app You will need the Ford coilpack, ignition leads, EDIS module, crankshaft trigger wheel and sensor, and as much of the wiring to those parts as you can get, making it easier to position or hide them wherever. That will be enough to get the engine running, then you need the Megajolt ECU, and you need to choose between a throttle position sensor (TPS) or manifold absolute pressure sensor (MAP) ignition advance control. I have only ever used the MAP sensor on both of my installations (Rover V8 and turbo 4 cylinder). The final bits are a laptop computer with a serial port to plug into the Megajolt ECU to configure it, and patience to plot the ignition advance map. Maps can be downloaded but you need to find a similar setup, although if you buy the pre-built Megajolt ECU from Trigger Wheels it comes with a turbo friendly map pre-installed.
pork
Sept 18, 2012 7:56:10 GMT
In your experience, is this worth buying?
Dez
@dez
Sept 18, 2012 8:30:19 GMT
the k10 engine has a perfectly good distributor and ignition system on it, the advance curve of which should be pretty well matched to the cam profile. I don't really see any practical reason for fitting MJ, but lots of pitfalls, such as the machining required to fit a trigger wheel. thats and its a lot of expense for pretty much no practical gain.
granted if you get it all together and are then having problems with ignition advance at certain rpms, then it would be worthwhile, but as it stands id get it running on the stock setup and only change it is there is a problem.
Last Edit: Sept 18, 2012 8:34:14 GMT by Dez
pork
Sept 18, 2012 8:45:19 GMT
Will do, thanks for input chaps. It all helps.
Sept 18, 2012 10:34:38 GMT
With a turbocharged vehicle you'll need to retard it to prevent detonation/pinging while boosting. So if your K10 is not boosted from the factory (and I'm pretty sure it's not) then mappable ignition is a must, especially since you're going to run stock CR you're more likely to detonation/ping/holeing a piston...
Sept 18, 2012 12:41:03 GMT
You could buy a scrap value saab turbo (with Trionic T5.5 engine management) , strip all the bits you need , sell on the rest as scrap (for the same as you paid for it) and end up with a very, very good, mappable turbo engine management system for little to no cash.
pork
Sept 18, 2012 15:24:58 GMT
How difficult would it be to fit all this, I.e, trigger wheel etc?
pork
Sept 18, 2012 15:26:10 GMT
You could buy a scrap value saab turbo (with Trionic T5.5 engine management) , strip all the bits you need , sell on the rest as scrap (for the same as you paid for it) and end up with a very, very good, mappable turbo engine management system for little to no cash. Sounds good, little bit out of my comfort zone tho as I really wouldn't know where to look/start
Sept 19, 2012 21:05:10 GMT
Midas
@midas
Sept 19, 2012 21:15:08 GMT
In your experience, is this worth buying? You can't buy the 'solder it yourself' ECUs any more so your only option is to buy a prebuilt version. I understand the reason for this was that they were forced to use components not suitable for home soldering. Anyway, if you had soldered it yourself there is are default maps for NA and boosted engines which would get you up and running safely. In my case I replaced the notoriously troublesome A series distributor which means I've had several years of trouble free running without having to fanny around with points, condensers and dizzy caps. Worth every penny for that alone.
