Sept 10, 2012 15:36:27 GMT
Hi All,
I have a 1970's sprite ariel caravan I am starting to renovate. It currently has a leisure battery with lights hooked up to it. I want to see if I can install an electric hook up and install plugs etc.
I have no idea where to start with this, does anyone have any ideas?
Many thanks
dgo
Sept 10, 2012 15:48:29 GMT
Sept 10, 2012 20:15:25 GMT
You need a proper caravan instellation and I would highly reccomend you get a proffesional in as mnay caravan sites are getting picky asking for your electrical test certificate and also gas test cert
Dave
Sept 11, 2012 12:37:39 GMT
Sept 11, 2012 13:09:20 GMT
lol, you wouldn't even need to "install" it. Just have it in a cupboard, and throw the cable out of the window to hook it up.
Would work even better if you had a squishy window seal, so you could close the window when it rains too!
If it's only small, and you wouldn't mind it... that could be the best option. Saves any certification hassle too, as it's just an E-marked electrical item, that's NOT fitted to the caravan
bigsyd
Sept 11, 2012 13:50:27 GMT
i have had a load of vans over the years and i will say this hand on heart leave your lights on the battery but fit 1 or2 to 240v. always pays to have back up lights and i always take gas cookers n heaters out. i replace them with electric items £30-40 sees you with 2 ring hob and a decent blow heater . thats about the price of a gas bottle refill. most sites you pay per day for electric may as well use it and cut expess of gas out aswell
2001 astra sri {soon to get a retro inspired make over)
1990 golf(put away for now)
Sept 11, 2012 21:17:45 GMT
You need a proper caravan instellation and I would highly reccomend you get a proffesional in as mnay caravan sites are getting picky asking for your electrical test certificate and also gas test cert Dave Can understand gas....but are there even electrical regs for caravans and motorhomes? I'm no sparks but given some of the site hookups iv seen over the years its a surprise that they'd pass inspection Have to agree tho...if your asking you probably shouldnt be doing
Sept 13, 2012 7:45:56 GMT
Ah thats great thanks - I will just get one of these then. Yes its really small its only 10 foot long. At present it just has 2 lights in and a gas cooker. Thats definiteley worth considering about removing the cooker then hmmmmmm
