ats
Sept 3, 2012 19:53:25 GMT
I picked up a E36 328 Coupe on Friday, drove the 30 Miles back with no issues, Give it a clean over the weekend (as it hadn't had one for the last six months)
Just started it up now and the brake pad warning light, ABS & ACS warning lights are all staying on....
I've quickly checked the pads, brake fluid and fuse and all are fine...
Any other idea's?
fred
WTF has happened to all the Vennies?
I had a e38 which forever said my pads were low, and my brakelights were out, oil was low, All were fine. May be just the computer going a bid senile
'79 Cossie ran Cortina - Sold
2000 Fozzer 2.0 turbo snow beast
'85 Opel Manta GSI - Sold
03 A class Mercedes
Looking for a FD Ventora - Anyone?
Sept 4, 2012 10:08:04 GMT
Have a look for water in the passenger foot well/maybe driver foot well - under the carpets. Think there maybe an ECU under there, could have got damp.
Sept 4, 2012 10:52:17 GMT
E36s love lighting up all their warning lights. A mate of mine had one, and most of his warning lights were on all the time.
Sept 4, 2012 11:35:43 GMT
Sept 4, 2012 22:42:18 GMT
I picked up a E36 328 Coupe on Friday, drove the 30 Miles back with no issues, Give it a clean over the weekend (as it hadn't had one for the last six months) Just started it up now and the brake pad warning light, ABS & ACS warning lights are all staying on.... I've quickly checked the pads, brake fluid and fuse and all are fine... Any other idea's? Yup they known for it, just like E34's... ABS brain is in one of the footwells, and ECU is in the scuttle usually (well was on mine) so I would check for flooding from when you cleaned it... Thick old sound deadening in these and can hold a heck of a lot of water if your door shuts leak! May be able to get your CEL to throw out fault codes if yours is an older model to check if there is a real fault or not?
andyborris
Sept 5, 2012 17:47:08 GMT
Try here www.endtuning.com/bmwcodes.htmlThink I saw some advice on his site about re-setting the codes. Sorry in advance if I'm wrong, it may have been elsewhere!
