Drift Trike buildRobinxr4i
@robinxr4i
Club Retro Rides Member 143
Sept 2, 2012 21:12:19 GMT
A good friend of mine Luke, came over a few days ago to help me clear my garage. He noticed the BMX frames in the corner and discussion turn to his hair brained idea to build drift trikes. Luke and another friend of mine Dave had spent an evening watching drift trike videos on you tube, so I did the only sensible thing to do and get involved too. The following day was spent visiting garden machinery dealerships and council tips, looking for suitable frames, wheels and plastic seats. Anyway photos. First off dismantle the BMX..... Out comes the grinder..... Cut the legs off an old plastic chair.... Rested in place to give an idea of layout.... Dave modelling.... Then because the frame seemed a bit flexible, I've cut and welded the cross bar to strengthen it.... Next step it to find a length of box or L section steel to make a make the back axle.
Wooot!!!
You may just be starting something here.
Will be watching this build.
Inspiration mate, Thinking of building one of these myself out of an old bmx i have lying around ;D
It matters not whether you win or lose; what matters is whether I win or lose. Steven Weinberg
Sept 3, 2012 12:21:47 GMT
Will be building one if these in the next few weeks
Sept 3, 2012 12:54:08 GMT
I do hope it's going to be powered Lol
Sept 3, 2012 16:50:45 GMT
Mine will be!
Sept 3, 2012 17:52:54 GMT
Awesome. I've also seen those vids on youtube. I'm bookmarking this thread and I may do something similar too
@robinxr4i
Sept 3, 2012 21:07:17 GMT
I do hope it's going to be powered Lol For now it's staying gravity powered ;D have got another frame though so maybe. Found a bit of random box-ish section, to make the rear axle. I've been told that the rear axle should be around one metre, so I cut the bar down to a metre which seems too long IMO. More photos. The cut bar.... Then cut the rear wheel mount to mate up to profile of the bar.... Made sure it mates up nicely.... Then turn up the MIG to max everything and then end up with this.... Think I'm going to reinforce the rear like this...
Sept 3, 2012 21:55:50 GMT
seen the video, if you know of a uk road this smooth i'd like to drive on it never mind drift trike on it.
theres more to life than mpg & to much power is just enough.
@robinxr4i
Sept 4, 2012 13:29:21 GMT
seen the video, if you know of a uk road this smooth i'd like to drive on it never mind drift trike on it. Yeah a lot of the videos online do seem to be in countries were there road surface is better than ours, but it should still be fun. TBH I'm just enjoying building it, even if it turns out to be unusable! Plus so far all I've had to buy is two 98p cutting discs, everything else I've either been given, found or had lying around anyway. Although I do need some small wheels with inflatable tyres for the rear, it seems as though most of these trikes run small inflatable tyres forced inside a piece of poly tubing. Like so....... Obviously the poly tube acts as the tyre would although with significantly less traction the tyre is just used to grip the tube. The wheels I've seen are 10" with the tyre and come with bearings, they are about £15 for a pair off eBay. Only problem then is getting hold of poly tube with an I/D of 10". Any ideas?
Steve
Making progress in small, easy to handle chunks of awesome
Sept 4, 2012 15:05:46 GMT
Only problem then is getting hold of poly tube with an I/D of 10". Any ideas? Surely it will need to be bigger that 10in? Need to allow for external diameter with tyre 10in + tyre = win
@robinxr4i
Sept 4, 2012 15:23:06 GMT
Surely it will need to be bigger that 10in? Need to allow for external diameter with tyre 10in + tyre = win No the wheels on eBay are 10" diameter including tyres, so 10" overall. So with the tyre deflated it should go inside a 10" I/D tube, then once it's inflated it shouldn't be going anywhere ;D Does that make sense?
Steve
Sept 4, 2012 15:41:48 GMT
Surely it will need to be bigger that 10in? Need to allow for external diameter with tyre 10in + tyre = win No the wheels on eBay are 10" diameter including tyres, so 10" overall. So with the tyre deflated it should go inside a 10" I/D tube, then once it's inflated it shouldn't be going anywhere ;D Does that make sense? Crystal mate ;D i haz been school'd
Sept 5, 2012 20:02:45 GMT
I'd have a look around construction sites for offcuts etc. Most ducting will be too thin wall to be of much use (well for very long anyway) but if you find any offcuts from gas or water mains you should be OK.
@robinxr4i
Ordered some wheels, bought four of them so we can split the cost Also I may have managed to track down some 250mm I/D gas pipe fingerscrossed
Sept 6, 2012 10:41:06 GMT
this is amazing!
Sept 6, 2012 11:46:57 GMT
You could, of course, bend up some sheet steel into a hoop (work out the lengths using some formula with pi in it ), weld and flappy wheel it up and you will have SPARKY skid wheels...
Sept 6, 2012 22:13:49 GMT
Can you buy that id pipe in your regular b&q or homebase?? Me and a few mates were thinking of making some. Could do with finding a good supplyer of that size pipe.
Sept 7, 2012 11:10:54 GMT
Looking at the vids the wheel seems to vary massively, so presume is more dictated by what pipe you can lay your hands on rather than wheel choice?
Would say most pipe in DIY places would be very thin wall, would work but wear or crack pretty easily. Possibly the thick wall soil pipe around 110mm would last a while though?
Sept 7, 2012 20:48:18 GMT
