ezzysi
Aug 27, 2012 20:37:27 GMT
Right, i'm basically determined to buy a VW T4 to convert into a camper for family weekends. I know there silly money compared to transits/sprinters/masters etc but my minds made up! a T4 it must be Also needs to be a LWB as the shorty's don't have enough room for my plans. What i'm after is the combined RR's collective experience/knowledge on what to look for when viewing, i've had a baywindow in the past but never anything newer. We spent 9 hours in the car yesterday and 400 miles being letdown by a hopelessly over-described van in eastbourne and want to be a bit better informed before setting off on the trail again! What the best of the 3 Diesels? do they have inherent weekness's? Have heard tales of cracked 5 cylinder heads and snapped cambelts etc Is there a big difference in mpg's between the 4 + 5 cylinder engines? Common rotspots etc How do they ride when lowered etc? I've joined the T4 forum and done some research but I also value the collective RR opinion. So..... what can you tell me?
1991 Mk2 Golf Gti 8v 2005 Passat tdi (daily) 1971 Mk1 Escort 2004 Touran (her's)
Aug 27, 2012 20:46:52 GMT
Timely thread for me,.. but I looked at the prices and they were a bit too spendy for me,.. so ... what are the alternatives as well
Aug 27, 2012 20:59:17 GMT
2.4 is dog slow butreliable as long as you change oil coolant etc regularly,they do seem to suffer from hg probs though, 2.5tdi comes in a few forms power wise, all are a doddle to uprate,cambelts(2) are a bot akward but once you have done it once easy from then on,dealer will tell you you cant change the injection pump belt at home as ecu learning blocks have to be reset, well as i did one last week can tell you its doable!! brilliant on diesel they just sip it, loads of power ut wrng wheel drive although one of the better ones!!
Aug 27, 2012 21:16:43 GMT
T4s are decent vans but really stupid money to buy lately - Prices for late t4s aren't far off the price of a much better condition t5 and there's really no comparison - T5s are really much better all round, and you can still buy all the parts from VW. VW are currently discontinuing most "trim" parts for t4s like sliding door steps, ashtrays, rear threshold covers and all the stuff that is generally bashed to hell on ex builders vans, which is really annoying and the used parts prices are flying up to reflect this. I convert them to campers as one of my on and off jobs and in the last 18 months the price of post 2000 t4s has gone up by about 40-50%. You could probably buy an early t5 with less miles on for about the same price, and T5s will wear the miles a lot better. That's not to say t4s are bad vans, it's just hard to buy one for anywhere near the right money unless its a petrol one or something which people seem to avoid like the plague. That said I drive a t25 camper daily and wouldn't swap it for a t4 unless it was something really special - they are sort of stuck in that "not new and nice/not old and interesting" zone. Anyway, T4s: Lower them 60mm and they drive ok but there's fairly limited front suspension travel up front, the bumps stops aren't too hard though so it doesn't hurt too bad. Lowering them this far is cheap - £60 for rear springs and just wind the front bars down, job done in about an hour. Cheap springs are curse word if you want to carry any weight but a normal camper conversion is OK unless you have got 4 people and all their luggage. They rust in various places but the sliding door runner is very common and very annoying, check it out right at the front, the runner track wears at the steel and it rusts through and the door runner bearing drops through the hole when the door is shut. Pain in the to fix properly because you have to weld a patch in perfectly flush or the door runner will grind on it, and there isn't room to get in on top to smooth the repair out with a grinder unless you cut half the side of the van off for access. Take some rags and a torch and wipe all the grease out of the front end of the runner and check it, look from underneath also, give it a good poke. As for engines, 1.9td are alright, 2.5tdi are quite good and you can remap them and make the a bit more sprightly if needs be. 2.4 none turbo are dog slow and super clattery but apparently dead reliable.
duncanmartin
Out of retro ownership
Club RR Member Number: 70
Living with a T4duncanmartin
@duncanmartin
Club Retro Rides Member 70
Aug 27, 2012 21:42:16 GMT
I'd be interested in hearing about the alternatives too. I like the look of Vitos, but they all seem to be incredibly rusty...
Aug 27, 2012 22:00:21 GMT
SWB VW LT would be one alternative, anything with a merc badge seems to rot, which is odd as the LT is the same shell, but much nicer engines and packaging of components.
Early MK6 tranny van, much better than the mK5 for rot and so much quicker, reasonable on fuel and good towing cap on rwd versions, cheaper parts than VW, no belts to change.
nutter81
I joined facebook so i could talk to the missus
Aug 27, 2012 22:10:11 GMT
my swb t4 2.4 is great runs on veg oil bit frilly around the edges mind
look out for the rear bumper mounts on the side of the van and also the sills but thats an obvious one check under the door step plastics aswell as mine is just a hole got to weld asap
door seals are expensive so try to check for leaks
sprayed mine at the gethering using 10 cans of graffiti paint looks good to
slammed 66
www.gtturbo.org
Aug 27, 2012 22:21:01 GMT
Don't bother with a 4 cylinder, you'll always wish you bought a 5 pot.
I had a 99 t4 2.5tdi with 230k on it and it was great. Only the 88bhp model but would still go over the tonne and did OVER 1000 miles on £102 of diesel (diesel was around £1.20 at the time)
Best bet is to look out for an ex AA van as they will have been regularly serviced and were given a power increase to 112bhp from the factory as per the AAs wishes.
They drive just like big cars. Scene tax is mega though so be prepared to travel for a good one. I flew from humberside airport to Aberdeen then got a train to Inverness to collect mine.
Ross
86 Renault 5 GT Turbo 89 Renault extra 91 Skyline GTR 98 Mini 1275 mpi 99 Autech Rider www.gtturbo.org
Stu
Just to add my experience with my T4. It's a 1997 2.4D (non turbo) SWB on 190k miles. It was a bit sluggish when I got it, but after a good service, new fuel filter, thermostat, belt change, injector cleaner and importantly tightening the throttle cable - it's much better. Obviously, it's slow, it's a large vehicle with not much power, but for what it is I think it drives very well. Motorway speeds, above 65mph or so are noisy and affect fuel consumption a bit (could do with a higher top gear), but otherwise great. It returns around 35mpg in daily use, mostly short trips. I've never run it on veg oil, but believe a lot of people do, so worth investigating. I've driven splits, bays and a few T25's and I'd say it drives much better than any of those, though obviously lacks the character of the older models. Easy to live with as a daily vehicle though, and oddly relaxing to drive with the high up view of the road and no reason to try to overtake anything Not sure if it's common, but mine has a gearbox oil leak that messes up the driveway and needs topping up every so often. I must fix that. Aside from that, mechanically it's good, and I like the lack of complication of the non turbo diesel and the mpg. I do have some dents, scratches and wheel arch crusty bits to sort out at some point though. Here's a pic of mine, camping in Cornwall a few months ago Hope that helps. EDIT: Forgot to add, I'm selling the camping interior from my van on eBay as I'm re-doing it. I've stuck a link in the 'For Sale' / 'eBay' bit on the forum if anyone is looking for this kind of thing?
Last Edit: Aug 28, 2012 8:58:27 GMT by Stu
I've been having similar van thoughts recently and have found it's really frustrating! VWs are all scene taxed (observation, rather than whinge) and all the old J stuff (which is what I'd really like) is off/gone to Africa! I spoke to our resident Merc specialist about Vitos at The Gathering who suggested that, at the low budget end of the market you need to buy one that's already had the injector seals done or you're looking at a. A lot of work or b. A lot of outlay on labour if you can actually find someone who wants to do the job! At least I think that's the gist of it...more knowledgeable people are welcome to elaborate.
I'm wondering about Toyota Power Vans...they're smart looking and seem relatively common. Any one had any experiences with them, especially economy-wise?
Aug 28, 2012 11:24:56 GMT
Ive had my 1.9td T4 for 5 years now, its a LWB and i can honestly say its been superb, we've done trips all over europe, i drive it to work every day and its always been reliable. A good alternative engine from the norm is the 1.9Tdi AAZ Conversion, looks fairly simple and all the info in on the T4 forum and the Brickyard. mines starting to look a bit scabby in a few places so ill be saving for a touchup next year.
As said lowering is easy 2.5tdi seems to be the choice engine and they are so easy to drive even my girlfriend drives it about.
as for alternatives, i HATE my works Vito, the bloody thing spends more time on the garage then being driven, whereas the Vivaro we have is lovely and i do like the bigger LT's
Dan
'90 Audi B3 Coupe 2.3 Auto [gone] '92 Audi S4 Avant 2.2 AAN Turbo Auto [gone] '93 Audi 80 Avant 1.9TDi [gone] '96 Audi A4 Avant 2.6 Quattro [gone] '97 VW T4 1.9td LWB [gone] '03 Skoda Octavia 1.9TDi [gone] '05 VW T5 Shuttle LWB 1.9TDi '15 VW Caddy Maxi Kombi 1.6TDi
Aug 28, 2012 13:06:51 GMT
My Caravelle. Caravelle's are LEZ compliant if it makes a difference to you, camper conversions are NOT. 2.4's are not THAT slow. I drive my velle to work every day, I have driven 2.5 TDi and 1.9tdi's for work, TDi's have more low down torque but the NA 2.4 diesel is quieter and revs better and higher. Petrols just drink fuel. The wheel arches and panel seams rust but not horrendously. Price wise, cheap ones are available. I paid £900 for mine last year, I have seen similar for £1200. Non turbo diesels are cheaper, as are VR6's. Good luck.
chess
Aug 28, 2012 13:28:57 GMT
T4's are more expensive, but they are far more reliable and unlikely to rust, they keep their value and are far easier to sell then any other van camper conversions. In 2010 I bought a T4 with 6 months MOT did a simple camper conversion, used it and sold it making a profit and didn't even bother renewing the MOT. Having had or driven all the engine combinations I think the 1.9 TD is the best engine giving best mpg/performance ratio. Look out for rot in the tops of the front chassis legs you cant see them from above very well but the MOT man can see them from underneath and check under a the plastic on the door steps. Lowering them is simple and doesn't affect the handling that much. You also have an big choice of cheap wheels that fit, I put mine on a set of Merc E class Avant Garde wheels that cost £150.
Last Edit: Aug 28, 2012 13:42:39 GMT by chess
Aug 28, 2012 13:35:18 GMT
From what I have seen/heard of T4's they are great vans, my friend has a 5 pot 102BHP model and its been perfect, no massive amounts of rust, and 100% reliable,
IMO they are better built than T5's however the drive is better in the T5's . If you want to get into the "scene" side of things they are easy to modify, although not always that cheap for certain things.
hkr91
Aug 28, 2012 14:33:50 GMT
Bought my Transporter brand new back in 2003 just as the T5's were being produced... VW, at the time, were doing a different trim package called the "Special X Pack" (basically for the last of the T4's) which included remote central locking (with flick key), electric mirrors, electric windows, cruise control, captain chairs (singles with arm rests) and featured the longer nose instead of the short nose. I also went for the single sliding door with a full one piece tail gate instead of the double doors. Keeping it short, I've converted it to a Caravelle (using a written off 'velle), installed my ICE, changed headlights to angel eyes, rear lights to LEDs, debadged grille, k&n panel filter, tinted windows, dropped the rear on springs and lowered the front towers, bought a gear knob extension (every T4 needs one) and finally added new wheels - although I now need new rubbers. Heres a picture of it half way though the mods. Haven't got any recent ones though :/ black is a pig to keep clean - shouldve gone for the They're not bad on fuel as others have said, I often get about 40MPG and ive got a very very heavy right foot. Mines also the 888 Pack (meaning its got a 800KG pay load and also is the 88BHP model) - to whack it up to a 102 BHP model you can just buy an intercooler off eBay (check as there is two types... two/four pin)... If you want more power, theres a few blokes on the T4 Forum that will change the injectors, increase the fuel from the fuel pump (also a lot of people tweak the pump themselves - just have to get the right balance before you start over fueling = loads of black smoke) and then remap the beast. You'll also need the intercooler too... I've heard of 170BHP but was running with the pump right up and a safe 150-155BHP. Failing that a simple intercooler and remap jobbie should suffice. Deffo go for the 2.5 five pot, I've heard mixed reviews from the 2.4/1.9s but they are what they are - a van and not a sports car. Before lowering mine did like to roll a little, now shes a bit more stable. Theres a show up in Malvern Annually called VanFest - thats not a bad show to pick up bits and bobs. GTi International used to have a vast selection of spares/upgrades etc but it's all phased out inlight of the Golfs/Jettas/A3/Polos etc.
mjd
Aug 28, 2012 14:40:59 GMT
The petrol ones aren't too bad -- I've got a 2.0 4-pot, does ~27mpg generally and it's a full camper with a hightop. Also it's smooooth and has more oomph than most of the diesel options And LEZ compliant, and petrol's cheaper than diesel and it doesn't do that many miles anyway and, erm.
Aug 28, 2012 15:17:00 GMT
From my limited experience of experiencing them on the road I think you need to put 18" + wheels on it and drive it in the overtaking lane at 65mph oblivious to the huge queue behind you.
bigt
I have been running a 1998 2.5 lwb for 2.5 years. During that time I have converted it from a rough builders van to a presentable day van. I wanted a 2.5 lwb with a tailgate but in the end settled for a barn door model. I was fortunate to find a 102hp intercooled example which makes for comfortable driving, 70mph around 3000 rpm and around 40mpg. Upside - it is a comfortable van, fitted saab leathers in front, easy to drive and looks the part. Lots of compaines supplying parts, etc Downside - not cheap to buy initially, lwb makes some parking abit tricky due to length and IF the engine goes wrong can be expensive. 2.5s are sensitve to cambelt changes, need setting up with laptop. As with all diesels clean air, fuel and oil and they will go on for years. 600,000 is common. Autoboxes are best avoided unless you really want one.
ezzysi
Aug 29, 2012 18:04:01 GMT
As expected, a raft of great information from the RR massive!
We live in the midlands so LEZ isn't an issue luckily, and I'm not bothered about it being a bit sluggish which reading the above means any of the diesels are going to do me just fine.
I've had a chat with an owner since posting up the original post, he's talked about fitting the fifth gear from a golf Gti box to give a higher top gear and better mpg's etc. apparently a quick job with the engine/gearbox still fitted due to the easily removable end cover on the box?.
Anyone done this?
Oh, and WHY are all the nice LWB's a million miles away !
Aug 29, 2012 18:13:28 GMT
the 5th gear mod is on my list but its not a gti box you want its an AAZ box, either golf or passat
