Hi.
I've an english axle and the diameter across the holes seems to be 90mm.
I've a mk1 single piece prop off a mk1 rs20000 which seems to be 79mm or so.
The question is can I change the end of the propshaft to a bigger flange and if so which one would I use?
Or as I am seeing now change the diff flange for one the correct size?
Cheers.
Cheers.
