Some people may recognise this as it was on an imp on here but basically I've taken it out.
It is well made and all bolts together.
Its a corsa C16xe engine and box. Box with hydraulic and also another box with cable clutch.
All the loom/ecu is there. As is the inlet manifold/exhaust manifold
Cable change gear linkage.
Both mini and corsa shafts are there.
Needs shafts made/tie bars fitted/ some sort of shocks/springs.
Any ideas of value or should I just break it?
Thanks.
Thanks.
