ftz313
Aug 17, 2012 11:11:37 GMT
Dug out my shed a sierra 4speed gearbox. Thought it was a type 9, had it next to a granada type 9 with electronic speed drive and the blinking propshaft wont fit. Sierra box is a lot smaller is it called a type c ?
Is this sierra box then worth anything or are they just rubbish. The reason I probably ended up with it when I thought I was getting a bargain !
Will a capri 2.8i 4 speed box take the same propshaft then as a type 9 ie. are the splines the same?
can i put a 4cylinder type 9 bellhousing on a v6 4speed box?
(ps I know about the input shaft being longer etc but I thought I'll just cut the end of it to use on a 4cylinder?)
Last Edit: Aug 17, 2012 11:13:06 GMT by ftz313
Aug 17, 2012 11:40:36 GMT
Sounds like it - does the gearstick screw on with a green plastic knuckle joint thing?
Worthless. I have a pile of them that no-one wants.
Yes. Same splines, close enough on length.
No. Or at least not on a capri one.
bortaf
Aug 17, 2012 12:09:14 GMT
thats a type 3 you have, better ratios than the type E or 9 but weaker and as you say the prop slines are differant as are the input splines everything else is a MrScarey states
R.I.P photobucket
ftz313
Aug 17, 2012 12:14:10 GMT
Thanks for the replies.
I'm being told that I can put a 4cylinder bellhousing on a capri 2.8i 4speed box tho?
Aug 17, 2012 12:58:16 GMT
You can't. Capri 2.8 had the type 5 gearbox which looks like this. It is a 3 rail box. iirc the only bellhousings available for the type5 are v6 fitting, english (essex) or german (cologne) Type 9 is totally different - it is derived from the consul/granada 2.5 type E gearbox and is single rail.
ftz313
Aug 17, 2012 13:28:56 GMT
right this is starting to make some sense. I've asked for some pictures of the box to be sent to my phone. I understand a bit better now. Thanks for your help.
I guess I'm looking for a 2litre capri box 4speed that'll take a type9 big propshaft.
ftz313
Aug 17, 2012 13:34:48 GMT
I've got a granada type 9 gearbox with an electronic speedo drive so I am going to just have to put that in. I.
bortaf
Aug 17, 2012 19:14:15 GMT
right this is starting to make some sense. I've asked for some pictures of the box to be sent to my phone. I understand a bit better now. Thanks for your help. I guess I'm looking for a 2litre capri box 4speed that'll take a type9 big propshaft. 2.0 capri 4 speed is typeF have a look here for some explanations www.burtonpower.com/tuning-guides.htmlYou can either change the rear casing for one with a manual speedo cable of just fit a leccy speedo? no idea how to do it mind you ?
Last Edit: Aug 17, 2012 19:15:48 GMT by bortaf
R.I.P photobucket
Aug 17, 2012 21:23:51 GMT
Type F? Is that the wierd thing with the external linkages? You would be miles better off with a cortina 2.0 4 speed. Leccy drive tailshaft on the T9 is easily swapped for a mechanical one - Drift the rollpin out of the selecter fork (under the gearstick, put it in third for access then return to neutral after the pin is out) undo the 6 bolts holding the tailshaft and the two holding the plate on the side. Remove the side plate, slide the tailshaft housing off the shaft. Now is a good time to fit a rear seal to the new one Re-assembly is obvious. Only gotcha is that if you forget to put it in neutral the spring and pin will miss each other and the gearchange won't work properly.
ftz313
Aug 25, 2012 22:45:01 GMT
Many thanks for the replies and the advice on changing the tail on the type 9. I nearly bought a sierra box that was poorly advertised but was outbid thankfully !
