Aug 14, 2012 22:14:00 GMT
Hi guys,
I've recently got myself a rover brm, but the throttle body seems to be a tad sticky. I've read it's a common issue with the plastic bodies which come standard on these. A lot of people replace them for the metal type, either the 48 or 52mm. My question is (as these are rather expensive and I'm a bit of a cheap skate!) I've found a 52mm throttle body on eBay. The advert states its from a 45/75 ZS ZT 2.0... It looks as if it's a little longer than the one I have but would this still fit? Without too much hassle anyway..
Cheers guys
Aug 14, 2012 22:27:45 GMT
Post the link and i'll let you know
Rover 100 - 1.8 VVC Street Sleeper
Aug 14, 2012 22:35:55 GMT
Aug 14, 2012 22:55:33 GMT
Last Edit: Aug 14, 2012 22:56:26 GMT by adriansi
Aug 14, 2012 23:06:06 GMT
Use a 52mm throttlebody from a 160 spec VVC engine - it's a direct fit. the 56mm throttlebody has been found to actually lose horsepower as the K series engine relies very much on pressure to function well. its for the same reason that de-catting the exhaust system for any K series engine is also not beneficial
sparkyt
selling stuff
K-series?sparkyt
@trevorhutchins
Aug 20, 2012 18:49:07 GMT
Or I could sell you a good tb still attached to an 1800 k series for 300 notes
gazwad
Aug 21, 2012 10:44:22 GMT
just get a 48mm ally tb off a later k series car - they are much cheaper than the 52mm and they make little to no difference in power.
Aug 21, 2012 15:16:21 GMT
Would the 48mm be too big for a flowed and cammed 1400?
Koos
gazwad
Aug 21, 2012 15:19:38 GMT
48mm is standard size on all k series except the vvc 160. it's good for anything up to around 180bhp then the 52mm has some benefit.
Aug 21, 2012 15:27:50 GMT
if you want better throttle response, you can remove the small brass inserts on the valve itself and fill the bolt holes with solder. a detailed guide can be found here: myothercarsa2cv.co.uk/howto/rovertb.htm
Aug 21, 2012 15:33:46 GMT
Ta guys.
Would it run more under boost?
Koos
p1RATE
Aug 21, 2012 15:47:42 GMT
There is a 52mm ZT160 throttle body for sale for £45 on MG Rover forums and one on ebay at that price at the moment. i wouldn't exactly call that expensive! If you combine this with a better cold air induction you should see a couple more hp too
• 13 BMW 320d
• 92 Pink/Purple Mercedes 190e (Project)
• 97 Rover VI 1.8 (track car)
