Its a bit of a weird question.
On my Fiat the clutch and brake fluid reservoirs sit in a small dark hole near the windscreen...
I intend relocating the battery to the front boot floor. I want to change the reservoirs for some shiney trick looking ones and fit them in the space the battery used to live in.
Problem is, if I mount the reservoirs in the space left by the battery they will sit lower down than the master cylinders.
I can make the reservoirs unclippable for bleeding or changing fluid but when everything is bled up and fitted will the reservoirs work as they should?
Where they currently are, they sit about an inch or so higher than the master cylinders but when I fit them to the battery tray the will be about 2 inches lower.
Will this work ok?
Can anyone see any reason this wont work?
Has anyone done anything similar and had problems/no problem?
Will this work ok?
