hi there all, I'm after some info on offsets of wheels. i can only get o offset and would i need -10 would it be a case of me getting the 0 offset wheels and getting a lathe man to take material from the face of the wheel that mounts to the hub? I'm confused please explain somebody thanks....eamon
hi there all, I'm after some info on offsets of wheels. I can only get o offset and would I need -10 would it be a case of me getting the 0 offset wheels and getting a lathe man to take material from the face of the wheel that mounts to the hub? I'm confused please explain somebody thanks....eamon Err no! the face of the wheel will be to thin to remove 10mm from this explains offset www.lexusownersclub.co.uk/forum/index.php?showtopic=11821
Removing material would give a positive offset, wouldn't it? Adding a spacer would effectively lower the offset.
RobinJI
What Ben said. If you want a lower offset (or more negative) to move the wheel more out-board, then you need to space the wheel out. If you want to move it inboard (and increase the offset), then you'd have to remove material, however very few wheels would have enough material to safely remove 10mm as the bolt holes will end up with very little meat.
What Ben said. If you want a lower offset (or more negative) to move the wheel more out-board, then you need to space the wheel out. If you want to move it inboard (and increase the offset), then you'd have to remove material, however very few wheels would have enough material to safely remove 10mm as the bolt holes will end up with very little meat. I've seen a set of Saab wheels with 5mm removed. I'm thinking of getting 10mm removed from the same type for a car of mine but I agree... it's pushing it! The 5mm isn't quite enough to avoid rub if you want to fit big tyres.
