so ive been asked by a mate to do some welding on some shutters on there chateaux (don't want to spend getting them pro welded due to the few thousand euro bill). ive never done cast iron welding before and just wanted to know whats roughly involved and whether its even possible to mig weld cast? ive heard that to get the best results, ill need to pre heat it of some sorts, is this true and would a butane blow torch be up to the job? also, what wire would i need to use?
Many thanks
Nick.
Nobody dies a virgin, because lifes curse word us ALL
AFAIK, you need to get it HOT, not just hot. I assume that these are big grate-type things, in which case a little blow torch is not going to cut it. I believe that lack of heating the surrounding metal causes the weld to crack when the bead cools.
Also, are you sure they are cast iron and not wrought iron? Most gates, grilles etc. are (or were) wrought iron.
MrSpeedy
East Midlands
www.vintagediesels.co.uk
You cannot MIG weld cast iron. Period. It is possible to MIG braze it tho. Without question THE best way to weld cast iron is with gas kit, using a flux and cast iron filler rods. The key is uniform pre heating and similarly uniform cooling to prevent cracking.
It is also possible to arc weld it, again using appropriate rods.
Tell them to get someone with the proper knowledge of welding cast iron to do the job. It's possible but needs skill so practice on scrap for a while before tackling. Definatley not MIG - gas or arc with special rods. It needs massive amount of pre heating and propane torch won't come anywhere near getting it hot enough for a large item. Even specialists aren't overjoyed about welding cast which gives you an idea what it's like.
Paul H
As above ,Its not worth the effort ,You might cause more damage than good it will fail .
jonw
Can open a Mouse with a File
Is a while since I welded cast but here's what I remember.
You will need a MMA (stick weld) plant with the proper cast iron rods for the grade of iron you are welding. The rods can be expensive and the gases given off not nice so I'd also advise good ventilation and a face mask.
The weldability will depend on the grade and quality of the casting. A very poor (lots of pores and inclusions) casting will not weld well compared to a good casting with good grain structure. A higher carbon iron will weld well compared to a low carbon iron and a nodular iron is another matter....
To weld you will need to clean up the faces, remove any dirt or grease, deeply V the faces and then heat the whole area up until it is begining to glow. You will need to heat not just the weld, but at least a good few feet (or meter) around it as well.
The weld in small deep runs, removing all slag and other impurities. Once finished re-heat the iron and allow it to cool slowly or it may crack. Cast rods can be a mare to start and run, especially on poor iron so it it stops, clean the run and re start.
A far easier (and cheaper) alternative is to braize it. You'll have the strength and it's less hassle. As above, clean the ends, butt together heat until brass begins to vanish. Remember to heat a wider area as the braize will wick up the iron and add to the strength of the joint.
Last Edit: Aug 8, 2012 12:14:54 GMT by jonw
Suzuki SV650R The good Triumph T20 The Bad BMW G650GS The Ugly Matchless G12CSR The Smokey Toyota Hybrid One pint or Two?
Ingredients of this post Spam Drunken Rambling of author Bad spelling Drunken ramblings of inner voices Occasional pointless comments Vile beef trimming they won't even use in stock cubes
Dez
Club RR Member Number: 34
cast iron weldingDez
@dez
Club Retro Rides Member 34
as mentioned above, braze it. its 100x easier than even attempting to weld it let alone getting successful results.
If you have a TIG then brazing with that and phosphor bronze rods is reasonable simple and very strong. Still need to preheat nice and hot
you rarley need a preheet with cast iron, the quality of the casting is more of an issue or if it has exotic properties. Some steel fillers can be used with some cast iron but they have to be for welding dissimilar steels. talk to a welding supply company and they will give you lots of advise but cast rods are very expensive . More important than a preheet is stoping post weld cracking so avoid draughts maybe cover with something after welding. After every pass chipp off the slag and pean the welds with the ball of a ball pean hammer to stress releave. Its not as bad as people say, buy a couple of rods and have a go. If it don't work , grind it out and try something else. I've been welding steel , cast iron, aluminium and stainless steel for 24 years and nothings as hard as people will have you think.
MK5 Transit MK1 capri
Depending on the branding, Fonte NI is the type of cast rod we use on cast at work (no idea of the brand but ours come in bright orange plastic sleeves) So look for that wording
Aug 11, 2012 11:37:31 GMT
she has got quotes from local welders in the area and they all want about 1500 euros per shutter and there a good 50 shutters on the ground floor (this chateu sleeps 30 people and is massive (chateau de bois giraud)
also when welding try not to leave any "missed edge" or any sharp edges as this are weak points and cracks can occur quite easily
I'm unfamiliar with cast iron however if a LOT of preheating is required, then Oxypropane is a good method,
Also use a weld wrap to keep the heat in to avoid shirnkage when the welding is finished
Aug 14, 2012 11:48:15 GMT
I've successfully welded cast iron with MIG. BUT, it does depend on the grade. I've welded cast iron heads successfully and a vintage cast iron garden roller, but had trouble with cast iron exhaust manifolds, but they did hold eventually when I turned the power right down. Doing a test piece is probably the only way to find out for sure.
I would say that 'iron' gates or shutters could actually be steel, unless they're very, very old. I was reading recently that most blacksmiths actually use steel because iron is too difficult to get hold of.
I pre-heated. I put it in the oven at top whack for about an hour to get it hot all the way through, welded it hot, and let it cool down slowly. If it's one join and you can't get it to weld, another workaround is to drill two holes and file a slot between them so you have a small dog bone shape. Fill it up with weld or braze to connect the two parts.
Aug 15, 2012 18:26:11 GMT
well i got hold of one of the scrap shutters from her place and test welded onto that. i pre heated an area and welded with alot of gas and full power and it seemed to weld ok, didnt crack or come off when i smacked it with hammer and chisel so all seems alright, i think its probably wrought or very rough steel so all should be alright hopefully
Aug 15, 2012 18:45:46 GMT
