Sitting deep in the "Shed of Dread" is the engine from a Dolomite 1500HL - engine number is YC-XXXX-HE which I've deduced is a high compression engine. That's good as it has a twin carb inlet manifold on it!
What difference in spec is there between this lump and the 1500 that went into the Spitfire?
