in the process of fitting a 2.0 pinto and t9 box in to my 89 riva, has anyone ever done this and came accross the steering problem where i hopefully need ur help. managed to get engine/box sitting where i need to but had to take sump and steering arm of as hitting subframe and the starter. need to chop axle beam out and remake round the sump bowl and also need to know if there are any easy options to fit a rack instead of a box, may be tricky as the box is right near the chassis rail.
any help appreciated
