FOAD
Jul 30, 2012 23:55:49 GMT
I bought a 1995 Fiat Panda back in March as a non runner, it still hasn't been started. It's getting fuel but no spark, replaced ignition coil but still no spark. Anyone know of common starting problems on these? The car had been sitting 4 years and was in the process of a new clutch being fitted, really the gear selector has been disconnected.
Really need to get this going soon as it's in great condition otherwise. I just don't want to replace every single electrical component if it could be a simple fix.
Any help appreciated.
Thanks,
Scott
1981 Vauxhall Chevette 1984 Mercedes S123 230TE 1988 Peugeot 305 GR 1988 Hyundai Stellar 1992 Subaru MV BRAT 1992 Peugeot 205 D-turbo 2004 Ford Ranger retroshite.wordpress.com/
Jul 30, 2012 23:58:13 GMT
these have two coils, did you replace both of them?
1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van 2006 Mercedes Kompressor Evolution-S AMG SportCoupé
"You think you hate it now, wait til you drive it"
FOAD
Yeah, both coils were replaced. Anything else?
Have a look at the fuses and the relay that do the ignition system, if they are okay, check that they are in properly, as on my panda they can work loose.
Jul 31, 2012 12:08:21 GMT
get it code read this will tell you whats at fault.
usually crank sensor
FOAD
Jul 31, 2012 14:13:49 GMT
Have a look at the fuses and the relay that do the ignition system, if they are okay, check that they are in properly, as on my panda they can work loose. I'll give that a try, Thanks
FOAD
Jul 31, 2012 14:15:08 GMT
get it code read this will tell you whats at fault. usually crank sensor What kind of machine do I need to code read it?
bl1300
Jul 31, 2012 15:59:35 GMT
A likely culprit would be oxidised contacts including fuses and relays give these a clean with some fine wet and dry.
Re code reader, take it into your local garage and get them to stick a reader on it. Cheap ones are available but they are cheap for a reason and there functionality is rather limited. Currently I cant access Autodata so can't look up were any diagnostics plugs are or what type they are.
Current fleet.
Jul 31, 2012 16:41:28 GMT
The diagnostic plug should be under the fabric roll (glovebox) in the passenger footwell.
bl1300
Jul 31, 2012 19:40:45 GMT
^ do you know if its OBD11 protocals? The kit ive got does OBD11 and anything post 2003 by then most manufacturers were using the same few diagnostic languages. Cost £50 of ebay.
The new kit ive got coming next month says its does anything with an programmable ECU regardless of age but that kit was £3k and that was trade price!
Current fleet.
FOAD
Have a look at the fuses and the relay that do the ignition system, if they are okay, check that they are in properly, as on my panda they can work loose. Swapped the ignition relay today and it fired right up, thank you for suggesting this, we're so happy it finally runs.
Good to hear, not much can go wrong with pandas, but can often be a pain to work out what problems can be. Also if you need any other bits let me know, as I have a decent stock of spares
FOAD
I'll let you know if we need anything, got a clutch to fit then see what it needs for an mot so will probably need something.
Quick video of it running.
