Jul 30, 2012 12:30:53 GMT
Hi,
I have started building a 2.3 i4 powered Morris minor and using a mt75 gearbox. Can any one tell me if i can use the standard ford galaxy flywheel and what could i get a starter motor off of that will fit this combination. also are all the ford spigot bearings the same size.
Stuart.
mikeymk
'85 Polo Coupe S 1.6 16v
Jul 30, 2012 14:01:04 GMT
Great engine, 2.3 version of the late Escort RS2000 unit. Also as a 2.3 in the late Scorpios.
I'd look to the Escort specialists for such parts if you've got the shillings, or the Scorpios if you're a breakers rat like me.
But then it's derived from the pinto, so you might just be able to use Sierra stuff?
bortaf
Jul 30, 2012 20:34:07 GMT
Last Edit: Jul 30, 2012 20:34:29 GMT by bortaf
R.I.P photobucket
v8
Not sure about the flywheel but the Galaxy cams are low lift jobbies.
If you can find a pair from a RS2000 it would give more power.
Scorpio 2 litre cams are supposed to be the same as the RS2000 ones but I've not checked this myself...
Thanks very much for the cam info i will need to get it running first which may be difficult as I have pulled the wiring harrness apart to remove all the bits I don't want, then i will have a play.
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
2.3 bottom end is a common upgrade for the rs2000's , use the rs2k head , flywheel etc , the 2k uses a mtx box,.
facebook: rodney dean / rd transport
v8
I would stick with the Galaxy head, the RS head has the thermostat take off at the back of the engine and you end up with a very high compression ratio.
I got just over 200 bhp out of a Galaxy 2.3 with 0.010" head skim, Vulcan engineering porting job, Kent RS2001 cams and GSXR 750 throttle bodies.
Also Emerald ECU to control it all.
