andyborris
Jul 21, 2012 16:50:39 GMT
Need a v-belt pulley to serve as an idle wheel on my BMW into Triumph conversion. After many hours Googling, I think a Mercedes 190 idle pulley will work, but can someone please take a measurements for me? Diameter, bolt size and number of grooves, the pictures don't show these details! And just to put my mind at rest, it does have a bearing built in, doesn't it? Thanks and have this for your effort
Jul 21, 2012 17:14:16 GMT
I assume you mean a serpentine belt pulley? I've got a few from the 6 cyl engines here, will take a pic and do some measuring.
andyborris
Jul 21, 2012 17:28:53 GMT
Thanks. Yes, serpentine belt pulley, I'm hoping to get one that'll serve in place of the power steering pump pulley. I need a grooved pulley that has a bearing in it. Ebay shows this one, which looks close www.ebay.co.uk/itm/120953831667?_trksid=p5197.c0.m619. I can bolt it onto the engine, with a spacer and it'll take the place of the pump pulley, (I hope!)
Jul 21, 2012 18:05:49 GMT
Yep that's the one.
Takes a 6 ribbed belt, and use'es an hex headed m8x1.25 bolt to hold it in place. The pulley is 70mm accross, but 58mm accross in the grooves. It is about 30mm deep.
Also has a bearing built inside it.
Last Edit: Jul 21, 2012 18:09:56 GMT by carat 3.6
andyborris
Jul 21, 2012 18:22:32 GMT
Thanks for the fast answer, I wish I could solve all the problems I'm meeting as fast (and as cheaply!) as this!
I'm off to spend a little money on Ebay ;D
Jul 21, 2012 18:30:18 GMT
Hope it dose the job for you.
