75nut
Hi
Cracked my rear screen on MX5 when I dropped the hood to quick on a cold day.
Got her back out for the better weather (lol, it will happen at some point!) and for the moment Ive covered the crack in poly tunnel clear tape.
I could get a new rear screen and fit it but wondered in any bangernomics experts out there had any clever way of plastic welding the cracks, or is that taking it a step too far?
90 Alfa 75 3.0 V6 Cloverleaf 79 MGB Roadster 88 Saab 900i Convertible 94 MK1 MX5 1.6 05 Volvo V70
Nah, its shagged and staying that way til you replace the screen or more likely the hood. The tape is as good of a fix as you'll get.
A whole new hood is about £150, and it's unlikely you'll be able to buy a new screen to zip into your hood. Best plan is to just save up and replace the whole thing!
Last Edit: Jul 6, 2012 16:29:28 GMT by cobblers
craig1010cc
Club RR Member Number: 35
I don't know if it would be any cheaper, but what about using some anti break-in film over the whole rear screen, wouldn't look any better as you'd still see the crack, but would seal it up pretty well
Is it a zip out screen? you can just zip it out and replace it,if its stitched in its probably new roof time.
In the meantime just leave the roof down and enjoy he glorious weather.....
Ginetta G15 BMW K1100 conversion Sold Mk1 Mx5 on ITB'S Sold TVR Chimaera 400 supercharged MR2 Red Roadster 2ZZ Bee*R 324 Skyline 95 Cherokee Jeep
I was looking for repair kits for my roof on ebay (my screen is ok) and found a lot of screen repair kits. I've no idea how well they work, but a roof re-skin is a PITA job that would take most of a day. The other option is to get a good roof already on a frame, then it's a bolt on job.
I've got Rovers.
Jul 10, 2012 22:49:05 GMT
Hi Cracked my rear screen on MX5 when I dropped the hood to quick on a cold day. Got her back out for the better weather (lol, it will happen at some point!) and for the moment Ive covered the crack in poly tunnel clear tape. I could get a new rear screen and fit it but wondered in any bangernomics experts out there had any clever way of plastic welding the cracks, or is that taking it a step too far? did the same thing to my old mx-5 just after i replaced the hood. didn't know your meant to un-zip the window before you lower the roof.
Jul 10, 2012 23:43:18 GMT
Is it a zip out screen? you can just zip it out and replace it,if its stitched in its probably new roof time. It's very much attached along the bottom seam. It's only zipped around the top and the sides for dropping the screen down. Having said that, lots of these hood repair/replacement companies can change the rear screens pretty easily if the rest of the hood is in good condition. The biggest problem is age. Once they start getting brittle there's nothing you can do. A nice fresh screen will happily fold day in day out without being unzipped but as soon as it starts to get brittle they start cracking. You can't remedy the brittleness once it's there. Yellowing of the screen is a sure sign that craking is on its way. Colder weather is also a screen killer - in the warm sunny weather, the plastic is more flexible but as soon as it's cold, if the screen is old and sun baked it's very likely to crack. I think it's somewhere in the region of about £60 for a replacement rear screen so not the end of the world?
MiataMark
Club RR Member Number: 29
I replaced the rear screen on a Herald convertible by sewing in a panel of clear plastic, bit of a bodge job but was OK for a temporary repair. Put sealant between the plastic and the roof. No idea whereI got materials from this was 30+ years ago
Jul 11, 2012 20:45:52 GMT
There's a place opposite my unit that does heated glass panels that just zip in i think.
I can make enquiries if you like.
Al.
75nut
Jul 11, 2012 22:06:54 GMT
Cheers gents someone on here messaged me and sold me a used rear section for £20 so result!! I don't think it will zip right in but I may be lucky. I know its not expensive ot get the repair done by the compaines offering it but I'm in north devon so the fuel to take it there would b emore than the repair unfortunately
Jul 11, 2012 22:17:10 GMT
It won't zip straight in I'm afraid. I've had an MX5 hood apart and removing the screen where it joins to the rain channel and to the main hood section is a real ballache. You'll need to drill some rivets out and get the ends of the zip undone etc....you'll pretty much be undoing most of the rear mounts and might even find it easier to remove the roof assembly completely rather than try and do it in situ.
After having taken an MX5 hood apart in the past, I certainly wouldn't want to do it myself and I'm not afraid of taking on most jobs. Also, be very careful when working on the rain channel, they are pretty fragile and can be brittle. Once they're split you'll end up with a lot of water getting into the car.
I hope I'm not putting you off, but please be aware, it's a lot more involved than just undoing a zip and doing another one up.
sparkyt
selling stuff
Jul 11, 2012 23:11:04 GMT
Only two studs to do and velcro at the corners then the zip at the top .. shouldn't be to hard
75nut
Jul 12, 2012 10:39:08 GMT
I did have an idea I might be able to stanley knife round the outside of old one leaving 1 inch then cut the new one out and bond it in if its going to be difficult. Bit of a bodge I know but this truly is just a fun car it does not have to be pretty.
craig1010cc
Jul 12, 2012 15:55:30 GMT
