Time to rid myself of more 'B spares!
First under the hammer is a New Old Stock Unipart Rotor Arm or around '80s origin. I bought this from an autojumble when iffy rotor arms were rife (and I was struck by this issue previously). I never had the chance to use it although it was always a backup rotor arm in my glovebox. This has never been used, although the packaging came off the back when I came to uncover my Alladin's cave of spares.
This will fit any Lucas distributor that is a 45D4.
£5 posted and this is yours
Second under the hammer is the indicator stalk of the non horn push variety although it will come with the horn switch for the centre horn push. This was removed for a 1976 MGB GT. It is in very good condition with a very positive feel to it, and not exhibiting that much wear for a used item. Probably one of the better stalks I have seen, and most likely it has been replaced at some point:
£12 and it's yours:
Also for sale is a wiper stalk off the same car with an overdrive switch fitted. This has got a little more wear present (wiper signal is just about visible, but it is in working order and in good condition.
£10 will take this.
Finally, a MotaLita steering wheel boss for a Horn push MGB (it is the B25C model). The copper ring off the back has gone missing (a copper ring and some wire should cure this), although these can be used on the later rubber bumper cars by carefully removing around 3mm off the rear flange (basically, where the horn push is).
£10 and it's yours:
£12 and it's yours:
£10 will take this.
£10 and it's yours:
