Doing this advert for my parents as I know the car better than them since I've been doing most of the service work and used to own it myself.
Tax 03/13
MOT 11/4/13
Nice Jag that's in good condition, doesn't get used a great deal but enough to keep everything working well, mostly long motorway trips.
The body is just starting to show its age - couple of blisters on the rear arches and a bit on lower edge of front wing, though hasn't really got any worse in the last year or so. It's still very good and much better than most X300s of the age and mileage.
Slightly odd spec; has the better 4.0L engine, but without cruise control, has full leather, but only drivers seat electric. Air con was working fine the last time I checked and it had a new compressor about 12months ago (so a major weak point you don't need to worry about). Also all the electrics work well, and believe it or not the clock even works! (well all the digits were working last week anyway)
Has a set of aftermarket wheels which are still in nice condition - clean up well. One of the photos show the old wheels, but it will come with the alloys shown in the rear end shots. Rear tyres about 18 months old so loads of life in them, fronts have reasonable tread (3-4mm?).
Although it is fairly high mileage (though these engines will do 300,000 easy!) it's always been well looked after and has extensive service history. Plus I know it's been well looked after for the last couple of years as I've been doing the service work! Did the diff oil seal (common weak point) about 2 years ago and 18months ago did a full service (all fluids including gearbox) and did all the ball joints and damper bushes at the front end (again another weak point on these). Has had a couple of engine oil and filter changes since then as well. Needed a pair of rear exhaust boxes for this years MOT, but otherwise got through fine. It is an old car now (which does make the insurance very cheap if you join the Jag Enthusiasts Club) so will need some maintainence at some point, but certainly nothing that needs doing soon - really has never missed a beat in the last few years.
£1500
If you're interested please call Dave on 01405 860026 or email snaithdave@hotmail.com
Tax 03/13
MOT 11/4/13
£1500
