13x4.5j
4x100 pcd
57.1mm centerbore
bmw 2002 steel wheels in reasonable condition, fitted with 185/60 tyres, all different budget brands, two tyres are useable, but pretty old. two have perished a bit, so in my opinion, not really suitable to use. 3 out of the 4 are delflated (i think this is due to some surface rust on the inner bead, which I sanded off, but didnt bother to paint over as I only used the wheels for a few weeks whilst I refurbed the wheels that were on the car, so wasn't overly concerned) The tyres would seal up fine if re-done with bead sealer, either that or sanded clean and repainted.
The wheels on a whole would benifit from have the paint stripped off and redone if you are planning to use them on a restored 2002. They are structurally very sound with minimal surface rust, front and back.
Probably made these wheels sound worse than they are, but I don't want you to be dissappointed with the condition of the wheels
the two useable tyres
close ups of each wheel
collection only from chipping norton, north oxfordshire. I will not post or wait for couriers
4x100 pcd
57.1mm centerbore
