Evening all, just having a bit of a clear out so putting some parts up for sale.
Barry Grant Speed Demon 750cfm carb with vacuum secondaries, electric choke, four-corner adjustment and the Idle-EZE baseplate. Effectively a heavily modified Holley item, designed to be more flexible and capable, and shares the same parts (as far as I'm aware). Suitable for mild 393-477ci motors. This is in excellent condition and full working order. Came off my '68 400ci Firebird. Comes with a couple of boxes of spare jets, pumps and so on, as well as a fuel rail with integrated filter and heat shielding. Do bear in mind that it'll need calibrating to your specification. £200.
Pair of cast iron Corvette C4 L98 manifolds. Ideal for a custom or rod build, or replacing damaged C4 manifolds. In good condition, with heatshields. Could also make a good candidate for custom turbo manifolds. Very compact. £40.
Set of GM Goodwrench pressed tin rocker covers. Sensing a theme here. These are new but have some minor paint flaking from storage. Ideal for chucking on an engine to get it going. £20.
Set of eight used Speed Pro hypereutectic pistons, part number H617. Got a few thousand miles on them but are all in good nick. Memory tells me that these are +30 but I'm not entirely sure. These were $30 a piece new. £50 for all of 'em.
Please feel free to make me an offer on any parts, or give me a shout if I've listed something incorrectly or if you want more details. More than happy to combine stuff as well if that's any use.
Posting and shipping isn't a problem if need be, or you're welcome to collect the parts. I'm located just outside Milton Keynes, in Bedfordshire.
Cheers,
Lewis
Cheers,
Lewis
