GavinJ
MGB 3.9 v8 Sebring
Club RR Member Number: 209
Mar 28, 2012 18:05:32 GMT
My daily seems to fail the mot every year with insecure CV boots, so each year I cable tie them back on.
Whats the best method method of keep them on for good?
I have just been to Halfords to get the crimping tool for steel cable ties, but typical halford they sell steel cable ties but not the tool to apply them....
Any hints tips or hidden secrets?
bortaf
Mar 28, 2012 18:46:29 GMT
gp to a PROPPER car spares shop and buy the tool ? or you can use nail pullers/pincers to crush the metal ones but IME the pliers will need tubes over the handles to get the thing crushed, cable ties never last unfortunatly
R.I.P photobucket
GavinJ
MGB 3.9 v8 Sebring
Mar 28, 2012 18:48:00 GMT
Yeah will have to wait for the weekend, only reason i ever go to halfords is the fact there the only place open when i've finished work.
Mar 28, 2012 19:42:06 GMT
E-Bay??
GavinJ
MGB 3.9 v8 Sebring
Mar 28, 2012 19:43:55 GMT
Retest is saturday, don't trust it getting here quick enough.
Mar 28, 2012 19:46:03 GMT
I always clean off any trace of grease from the area on CV joint and boot where they will touch before using cable tie. Never then had a problem with them comming off.
Paul h
scruff
Mar 28, 2012 19:59:00 GMT
I've used these on the Esprit, very easy to fit using pliers and no chance of them coming undone. Can get them flipping tight too
1994 Lotus Esprit - Fragile red turbo with pop up lights. 1980 Porsche 924 - Fragile red turbo with pop up lights.
I spy a trend...
Mar 28, 2012 20:42:56 GMT
Ive always used (good quality) cable ties and never had a boot fall off
Mar 28, 2012 21:33:12 GMT
I too have also tried cable ties and the metal 'universal' zip tie like CV joints. However, I could never get them to stay on, even with my best efforts of cleaning the CV and boot mating areas. On the inners I shall admit that it seems you can get away with cable ties.
A proper CV clip (well, like Scruff's) with the tool (same for undoing those one use breather pipe clips (if you know the ones I am referring to) does the job very well, or at least it has on the 205. Near me, almost all motor factors sell them (an independent, GSF, and ECP to name a few). You should find something to do the job near yourself.
Last Edit: Mar 28, 2012 21:36:23 GMT by ChasR
tomgt
Mar 30, 2012 15:46:28 GMT
Yeah, would agree that cv clips would be best but cable ties etc work just as well.
On the hunt for a taxed a tested retro ride, hatch or coupe. Under 1500 if possible
What have you got?!
Life isn't the same without a car....
kcchan
Mar 30, 2012 17:18:47 GMT
Why don't you cable tie it on for the retest, just incase the tool doesn't arrive before then?
