hi all I have my 1985 autosleeper for sale as ill health I can not do the work it needs for its next mot ( mot runs out in april )
it has tax but it can not come with the van as it is Disabled but you can drive it home.
it will need welding to both iner and outer sills and the iner arch on both sides the rest on the under side is very good. both sides of the A post round the screen needs welding ( not needed for mot )
the body will need work and welding. it has a dent on the bonnet and the van has been hand painted
the engine runs very well. it has just had a new clutch and cable. all gears work as they should. it has fitted a s/steel twin 3" side pipe. it blows a bit from the back of the engine but its not to bad but will need sortin for its next mot.
to start the engine you need to push a starter switch and also has a hiden kill switch
only 1 key for the drivers door. all the rest you have to open from the inside.
the speedo cable does not work ( I use my sat nav )
dash heater does not work.
the dash has been hit by the sun over the years and does not look good
the camping area is very good with the 2 hobs and grill working fine. it has a on board water tank and the cold water works in the sink and shower but I can not get the boiler working so no hot water.
the fridge works on 240 and 12v never tryed the gas so it may work.
the gas heating works very well.
it has a bed for 2 people in the roof and the 2 seats with seat belts can make a bed for 2 more to sleep.
the 2 front drivers seats are from a transit and the drivers side does not spin round. the other side is ok and makes a rear faceing seat.
it has a tow bar but I have never used it.
lots and lots of paper work for all the jobs it has had over the years.
I can get the price I want for it by selling it off it parts but I think this old van still has life in it.
if you can weld you could have this back on the road for not alot off cash.
call 07845886240 or pm me
