Feb 28, 2012 12:38:14 GMT
My rad has a crack at the top on one of the "end tanks" rather that the main surface area. Is chemical metal non porous? And how it is for setting in damp locations. I do have a heat gun. But just in case the crack seems some coolent whilst it is setting.
Any recommendations for this type of job?
Thank You
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Feb 28, 2012 13:05:34 GMT
Is this a plastic or brass end tank?
Feb 28, 2012 13:20:48 GMT
I once had the hose spigot break off of a plastic radiator top tank. I took the radiator into a local radiator shop and they replaced the top tank for a very reasonable fee. Well worth it if you plan on keeping the car long-term.
Feb 28, 2012 15:32:43 GMT
pretty certain plastic
Feb 28, 2012 15:33:37 GMT
some ford radiator not certain what, as it's not original
Feb 28, 2012 15:40:23 GMT
I have tried this before on a BMW radiator (E32 730i to be exact). The simple answer is how long is a piece of string?
On the BMW it lasted two weeks before it started to leak again.
Feb 28, 2012 15:54:48 GMT
If it's a plastic rad you can repair it using a soldering iron and a piece of scrap plastic. First "stitch" across the crack with the soldering iron and then melt some plastic over it. If it's a copper rad you can use regular electronics solder (I know it's weak, but since it's not structural it'll be fine) and a small torch, or some plumbers solder. Products like JB weld seem to work fine, but I have no real long-term experience with them, so can't really comment on that. Maybe some regular plastic glue would be enough...
Feb 28, 2012 16:01:17 GMT
Or, get some dimensions and go hunting. I got a brand new Mk3 Fiesta 1. rad for my Dolly for £25... There's been at least half a dozen more on at around the £30 mark.
mikeymk
'85 Polo Coupe S 1.6 16v
My '85 Polo rad had seen better days, i just looked around a breakers for one that i could make fit reasonably easily - ended up finding a Renault Megane item to do the job.
Yeah it took some light fabrication of brackets, and i had to find an alternative inlet hose that'd reach around comfortably (bearing in mint the thermostat housing is a different design on this '02 16v engine). But i figured it better to invest my time doing that than mess about with sourcing or repairing an ancient design fast becoming obsolete.
Brigsy
I used plumbers mate (basically the same as quicksteel) to repair a cracked plastic coolant swirlpot to keep me on the road until a replacement was found, worked fine. You can apply plumbers mateon damp surfaces. Its a bodge but will probably get you away until you can find a replacement rad.
Last Edit: Mar 1, 2012 14:47:54 GMT by Brigsy
Rich
Club RR Member Number: 160
chemical metal / radiator repairRich
@foxmcintyre
Club Retro Rides Member 160
I used plumbers mate (basically the same as quicksteel) to repair a cracked plastic coolant swirlpot to keep me on the road until a replacement was found, worked fine. You can apply plumbers mateon damp surfaces. Its a bodge but will probably get you away until you can find a replacement rad. Not to be confused with plumbers mait. Plumbers mait is a soft non setting putty for sealing the bog to the soil stack and stuff. Won’t do a radiator.
Jul 27, 2020 21:36:00 GMT
After all those dodgy porn films from the 70's and 80's I'm very reluctant to google "Plumbers Mate".
Confessions of/from a _____? Some of those were fairly amusing as I recall.
Brigsy
Jul 31, 2020 20:39:11 GMT
I used plumbers mate (basically the same as quicksteel) to repair a cracked plastic coolant swirlpot to keep me on the road until a replacement was found, worked fine. You can apply plumbers mateon damp surfaces. Its a bodge but will probably get you away until you can find a replacement rad. Not to be confused with plumbers mait. Plumbers mait is a soft non setting putty for sealing the bog to the soil stack and stuff. Won’t do a radiator. I cant even remember posting this bumped by a spammer by the looks of it. It was actually evostik plumbers mait that i used, confusing but the same name and its the same as quiksteel but cheaper www.therange.co.uk/diy/hardware-and-accessories/household/plumbing/evo-stik-plumbers-mait-repair-putty/#186551Still carry some in my get me home box, good stuff.
spammer alert! I have just clicked "report post" can others do the same, it will help the forum a lot.
I have used JB Weld [its much the same as chemical metal] on a ford rad plastic end tank, bodged up a 1/2" sized hole in it where a support was that got broken off, it did a very good job but the rad has to be drained and dry really.
I have used upol fantastic with good results
