Mileage: 200,000ish
Tax: 4 months
MOT: mid'end april 2012
Price: £900 or p/x swaps
This is mainly an offroad vehicle but is road legal, don't be expecting a nice luxary daily, as it is not that! Goes extremely well offroad and is ok on road feels abit wobbly and steering a bit vague due to the suspension lift and Knobbly tyres, possibly the front shocks are worn as well (i have fitted brand new rear ones). Hasn't caused me any problems ive driven it all over just takes some getting used to driving as do all moded 4x4s.
Good bits
manual, mot til mid april and taxed, rear to drive away.
highish mileage but always starts and runs perfectly.
has 265/75/16 insa turbo tyres on alloy wheels ally tyres have very good thread, they havnt done many miles (these cost a bomb), also has brand new spare and steel rim.
front winch bumper fitted, heavy duty steering guard, front and rear diff guards,
light bar fitted and all wired up,
safari snorkel (expensive one, not home made rubbish)
wind guards on the front doors to reduce road noise when windows are down.
has a pro comp suspension lift 2 inch, and 1 inch raiser blocks(raer) and with 2 inch lowering shock mounts, new rear shockers fitted(pro comp same as front), great articulation.
new radious arm bushes and prop coupling.
All gears select and work as they should, as does diff lock, hi + low etc.
has cobra alarm and immobiliser fitted.
tinted rear windows.
has a cd player and some speakers fitted.
Bad
off road body work, its not a minter, dints here and ther etc, pulls the off roader look.
kicks out some smoke when cold for the first 5 minutes, then is fine after that.
pretty solid, boot floor has had a few patches before i got it don't think it will need any more, will probs need a few patches on the inner rear aches in the corner, and one pact on drivers floor. Cant see another welding that needs doing.
chassis is solid, shudnt need much work for another mot. straight thru exhaust, needs a tip at the rear as alittle short.
no carpets fitted, due to going in water. rear bumper is broken on one edge and is tied on and needs either refitting or removing.
driver seat belt mechanism is stuck but i will try and fix this before the end of the auction.
will need the drivers side rear seat belt mounting point(one on the arch) welding, as this has come away, not a big job
Tax: 4 months
Good bits
Bad
