bstardchild
Club RR Member Number: 71
Citroen Ax Wiper motor Wiringbstardchild
@bstardchild
Club Retro Rides Member 71
Jan 16, 2012 23:09:29 GMT
For a single wiper conversion on another car (old twin wiper died and I don't want to used a valuable spare on the car)
So puchased a Citoen AX wiper assembly inc wiring plug plug with a length of the loom and now I find I need some help/info re wiring
What is it with the French?? One yellow wire and four grey ones.......
All I'd like is two speeds (not bothered about intermittant unless it's easy) and I don't care much where it parks ;D
robg2
Jan 19, 2012 20:45:26 GMT
I'd guess that the 4 grey wires weren't grey when they started life.
Dismantle it and see what's connected to what.
Jan 19, 2012 20:56:48 GMT
All the power comes from the relay - it parks the wiper, so you may have problems with it doing a full 'wipe-park' cycle. Here's a wiring schematic: From looking at that, connect the yellow to ground, I suspect one grey is green and the rest are different speeds (intermittent, 1 and 2).
Jan 19, 2012 21:00:46 GMT
its a citroen, the wires will have been grey from new (actually its a valeo part so ) citroen love lots of green and grey wires.
robg2
Jan 19, 2012 23:07:24 GMT
Oh...! RR rocks!
ruffgeezer
Attracts french tat.
Jan 19, 2012 23:15:44 GMT
If I get a chance before I scrap it, did you want me to chop the relay, plug and a bit of wiring out of my ax?
bstardchild
@bstardchild
Jan 20, 2012 18:19:03 GMT
If I get a chance before I scrap it, did you want me to chop the relay, plug and a bit of wiring out of my ax? I love RR.......... That would be nothing short of superb!! I was only planning on having a minimum of 2 switches speeds and runing them off a two position rocker switch on whats left of the dash I'll cover any postage and packaging costs of course
bstardchild
@bstardchild
Jan 20, 2012 18:21:02 GMT
All the power comes from the relay - it parks the wiper, so you may have problems with it doing a full 'wipe-park' cycle. Here's a wiring schematic: From looking at that, connect the yellow to ground, I suspect one grey is green and the rest are different speeds (intermittent, 1 and 2). Ha ha - I've had a really close look at all the grey wires and one has a tiny flash of green on it right next to the plug Thanks for the wiring diagram too - I'll get my head round that
Hi,
Did you managed to get using this wiper motor? I bought mine long time ago well 4 years ago.... starting wiring now into my Mini.
Thanks Atchi
Building roof chopped, screen raked '68 Mini with G13B 1.3 16v Gti engine with LSD, Yamaha R1 carbs. As well as mk1 Suzuki Swift Gti AWD with a turbo. Drives PHEV Outlander but wishing my mk1 Swift Gti or mk2 CRX Vt were still with me!
give me a few days till i get a day off work, ill take a meter outside.
Thanks ax16vts.
I have a 5 wire connector with the motor. Can you tell me how many speed does it come with? My set up(switch) has 3 setting as follows. inter mitten, slow and high speed. It should come on when you use screen wash as well.
Thanks Atchi
might bw a little while yet... tried yesterday, battery flat - left charging Went to remove the scuttle this morning to access wiring and sheared the screw off!
When i get access ill post details, IIRC its two speed and comes on with the screen wash..
much appriciated
Jan 27, 2014 12:54:34 GMT
Hi,
I found out 1 earth, 1 slow and 1 fast. I still have 2 wires I don't know what they are for. Can anyone help me?
Thanks Atchi
Jan 27, 2014 16:48:56 GMT
I found out 1 earth, 1 slow and 1 fast. I still have 2 wires I don't know what they are for. Can anyone help me? Thanks, Atchi Hi, sorry can't help but if I was guessing 1 would be "park" and other may be doubled-up with something else (2 earths? "pass-though" for the main feed?) I just posted to offer my sympathies! ( had an AX, but also had a 'mare trying to trace a voltage loss on a Zantia - sure the whole harness only used 2 colours) Happy times...
