Bought this welder to replace my Clarke, but it needs to go as due to another acquisition, space is a bit tight. Open to offers.
S0817 - Sealey MIG Welder 180Amp 230V
Photobucket is being a dick, so here's a library pic for now. Apologies.
Here's some copied specs:
Features heavy-duty high output transformer and forced-air cooling to ensure the highest level of performance. Suitable for welding with CO2, Argon or CO2/Argon mix. Contoured grip, non-live torch is comfortable in the hand, thus ensuring a steadier weld bead. Includes industrial gas regulator, spool of wire, contact tips 0.6, 0.8mm and gas cup.
Welding Current:
30-180A
Wire Capacity - Steel:
0.7-5.0kg
Wire Capacity - Aluminium:
0.5-2.0kg
Duty Cycle:
100% @ 56A, 75% @ 65A, 60% @ 73A, 15% @ 145A
Cooling System:
Forced Air
Gas Type:
CO2, Argon, CO2/Argon Mix
Torch:
Non-Live
Power Input:
230V - 1ph
Absorbed Power:
5.7kW
It's a great welder, and is superior to my Clarke to be honest. It has barely been used, just sat around in the previous guys unit. One wheel has been repaired as the fixing was damaged. Some insulation tape on the torch lead. Case etc looks almost new - as the machine is. Takes large bottles.
New price on these are from around £340-over £600.
£200 ono. Can possibly courier, or deliver. Collection preferred.
Welding Current:
30-180A
0.7-5.0kg
0.5-2.0kg
Duty Cycle:
Cooling System:
Forced Air
Gas Type:
Torch:
Non-Live
Power Input:
230V - 1ph
Absorbed Power:
5.7kW
