will930
Decked K11 Micra - RetroRunner Mk2 Golf
Dec 27, 2011 19:00:28 GMT
as you may have seen ive bought this for £400 from a grage which I know quite well, I was able to drive it around the private industrial estate for 10 or so miles and it drives well, just needs lots of love after sitting for 8 years outside!! so heres the car running the supposedly strong non-TVIS engine! with 103000 miles needs a massivle clean... but today I started looking thoughly over the car! due to the tyres going flat very quickly and making it hard to move as I need a battery I went about fitting my old micra steel wheels! so it can be easily rolled! while doing that I thought id remove the side skirts to inspect the cills and was greeted with this! on both sides!!!! and rust on the arch and then at the window I am going to throughly inspect the car too! the brakes after sitting for 8 years! needs new rack gaiters and I'm not sure if the perished rubber sleeves around the rear shocker will be a massive problems! thats all for now! but I am planning on getting it on the road for march time, for a 2 month shake down then bring it back in for almost a full rebuild! then at some point I plan on getting a second engine and building a high power turbo engine and aiming for a cool 260-300hp which ive been led to is possible! ill keep this updated
Last Edit: Jul 19, 2014 16:54:49 GMT by will930
Dec 28, 2011 17:49:27 GMT
always liked these, good luck with it
will930
Dec 28, 2011 18:07:43 GMT
I'm looking forward to getting it on the road!
will930
got a little time down at the garage today! started stipping out the rear end for furthur rust hunting, removed the seats and all the trims on the drivers side and nothing, but ill leave it out for now untill its welded up and i can go mad with the waxoyl! also popped out the rear window too and gave it a clean! and a little bit of rust and behind the trims i found still in the celophane and remember this little bit of rust well i pulled it all apart and cleaned it a little not sure how ill tackle that, i may use fibre glass of wait untill i can get my hands on a welder and fill the hole, ill have to wait.... so far ive been removing trims and cleaning it a bit as i don't have water at my garage so i just wipe it down with a damp cloth lol by this time it was dark...
Black F reg very local to me- nice and original Mica blue and E reg makes for rare combo
milan
Good work mate,glad to see your stripping it back slowly,it can be soul destroying to find alot of rust staring back at you but once its not toof ar gone it can always be repaired! One thing to avoid is using fibreglass! Fibreglass isnt the answer to holes,new metal is!
nice find cool retro bus that
will930
Jan 15, 2012 19:17:02 GMT
well i don't have a choice using fibreglass around the screen, but when its stripped for its respray it will get the treatment it deserves to last another 20 years
will930
Jan 15, 2012 19:17:41 GMT
bit more of an update with plenty of pics as we all love pics i stripped out the rear end and the drivers side a little to check it over etc.... found the rust the rust cleaned up etched as i don't have a welder and the screen is still in i wouldnt risk it, so fibreglass added fibre glass rubbed down fibreglass rubbed down filler added filler rubbed down primed up not 100% happy with it but it will do for now rear drivers side window removed found some rust bubbled up i got some steering rack gaiters and some track rod ends, only had to get the ends as the old ones had to be butchered off and doing it with a dremel isnt fun haha, i need a grinder old hacked off new fitted slight issue, i wont bother with it now but doesnt seem quite right to me, after asking the auto factors for power steering gaiters and they offered universal ones so i said yeah but at full lock with the arm at its shortest dead ahead full extension not sure how long they will last but its better than nothing
something I will keep an close eye on, as these are my Fav cars, at this moment of time, I have the mk1 Corolla GT ae82 with same engine as yours, getting repaired and being brought back to life.
Last Edit: Jan 26, 2012 7:24:17 GMT by Hussain
will930
Jan 29, 2012 23:08:37 GMT
thats awesome its aiming to be on the road by the end of feb early march, its not too bad really it needs a massive clean
Jan 30, 2012 12:02:07 GMT
Used to have G reg one of these.... used to go like a train but my god was it rusty! If i parked it on a hill with more that £10 of petrol in it, it used leak out and run down the road lol! It eventually went bang one day on way to work in 2003 making such a loud noise everyone in the bus stop opposite ducked!! Was huge fun though for a front wheel drive car.... good luck with your resto!
Speedle
Jan 30, 2012 13:12:19 GMT
Great cars these but my god do the rot! Hows the sunroof area? Some tidy repairs dude, should keep the rust at bay for a good while
rdy416
Jan 31, 2012 18:03:17 GMT
hey will looking good so far mate your car has the tvis on it mate whilst shes in bits do yourself a favour if you havent already and take the rear pannels out of the back like rear door cards and rear arch trims and check the rear turrets mate to make sure they arent rotten since your tackling the rust anyway if you find rust on the turrets then get it sorted straight away ;D it will save you hassle later on
will930
Feb 25, 2012 18:06:58 GMT
time for a rather substansial update a lot has been done in my opinion! i had a member of the AE92oc website come down from milton keynes on a very cold Feburary 11th to bring down my new gearbox and to help me fit it! starting out the new box in a very fething blue, which is cool because blue is awesome part of the reason for the old gear box failiure i presume, not even a quarter of a litre came out! i was expecting bits of 4th gear to come out random image of driveshafts the cleanest bolts we found! under the car lol wide shot of the 2 cars now the gearbox didnt want to let go at all but we finally won, which wore us down alot the old clutch, which was pretty bad no wonder it slipped nice shiney new clutch ready for some destruction, its only a cheapo jobby though new box ready to go on, sadly it gave some issues going on, but we won in the end by this time it was dark and must have been about -4°C so they left and i went home for the hottest shower ever! and the following monday i set back to work to get the annoying rear mount in, which ended up with the engine pulled right forward and lowering the subframe! was a poop to do! then connected everything up and i was done simply needs oil and brakes so i can wizz it around the block
Feb 25, 2012 18:13:12 GMT
Keep up the hard work, it will be all worth it.. sweet ride!
will930
Feb 25, 2012 18:15:31 GMT
then i decided it was about time i got this welding done out the way, but down my garage with no leccy or welder was a different matter, id managed to borrow a mig and had swapped my massive generator for a smaller 2Kva unit which leaves more space in the garage (thanks ed) from the pics before there was alot to do and i didnt feel greatly confident lol, so i set to work old section cut out on pass side new section cut out lined up and finally welded it was kinda tricky to get a decent tack from the welder it was rtight down low but as i started it would splatter but when the genny picked up it was fine and i could get a decent weld a small hole i found while pocking about inside the wheel arch the rot cut away new metal finally in now onto the drivers side which i appear to be lacking pictures lol wheel arch done cill and all the old rotten metal cut out note to all! don't let molten metal fall in your ear! it hurts and to you welding buffs out there i know its not amaxing but its strong
will930
righto to follow on from that annoying welding i had the task of the annoying filling etc, trying to make it perfect etc, eventhough its being covered in stone chip and then hidden by the side skirt it didnt matter lol trial fit of the side skirt over the wleding, at least it fits.... fibreglass applied and rubber down. horrid stuff at the best of times but its there to help strengthen and is much stronger than plain filler somehow i managed to forget any pictures of the filler, but it didnt take much as id done more with the fibre glass, i used the filler to give me the shape and a nice smooth finish for the primer masked up the areas and gave a coat of etch primer on the bate metal and then 3 thick coats of normal primer to give a good finish and done on the drivers side # and because I'm llame and wanted to get it done no pictures apart from finished of the passenger side, its not the best but i remembered what i said at the begininng so here it is once the car has T&T ill swing it into my work for the spraying to begin, id rather it done properly for a good colour match for a start!
will930
now time for the brakes, this became such a nightmare, and labour of love but the needs must as i was itching to test the new box and clutch out so here we go removed all the brakes and cleaned the hubs! not great but removed the cobwebs which i hate lol the old brake pads from the front, not alot left, wasnt going to reuse them anyway and a box of manky old brake bits to be cleaned and a closer shot of the fronts rears removed and in a very similar state! and a cleaned and wiped down rear hub! after about a day of shot blasting in total they were all ready for the damaged rubbers to be replaced and to get a lick of paint! the front carriers came up first which are in gloss bvlack coat of etch coat of primer 2-3 coats of black depending if i remembered the front calipers were rebuilt sadly no pics but its boring anyway and a coat of gloss silver and the finished product ready for assembly and assembled waiting to go on the car and finally fitted, and looking clean and shiny and now the rears not many pics again as it was very much the same process of painting and replace the damaged rubbers rear callipers fitted you may ask why ive resued the disks, its because they had plenty of life left, and i didnt want to spend out for new ones just now as they wont be oin there long untill something better went on p.s. i know the rear calipers in them pics are upside down! and the handbrake leaves alot to be desired hope this isnt boring too many of you guys!
will930
a little bit of under bonnet bling started off looking like this then found the part and painted it AJ4 nissan red same as my micra and fitted tidies it up a treat i think
