Some years ago, I used to have a 106 Rallye and had grand ideas about stripping it out FOR LIGHTWEIGHTNESS AND SPEED AND POWER FOR TRACK DAYS. I took the back seats and carpet out, but all I did was drive to work in it, so it was a bit of a waste of time and not long after I put all the insides back in and was glad of it.
Anyway, I'd planned to take the dash out and the heater box too, but I wanted a half decent demisting system. So I ended up with this:
(Apologies for the curse word photos, They were taken using a slice of toast)
The matrix itself is brand new, but the fins on one side have a few "dings" from stuff being stacked on it in my bottom drawer - nothing that will anywhere near affect anything, just a few marks really.
The fan was used last summer for a bit, sat in my window piping cool air in down a bit of aluminium ducting to stop me from sweating down to the size of prince. It worked great. It runs off 12v, and blows something like 130 cubic feet per minute which is a fair blast. It's probably slightly under what a normal heater fan kicks out on medium, ideal for demisting and only draws half an amp, which is good if you're running a dynamo or whatever.
I've got another fan I'll throw in if you want more power, and also a grille for the fan if it's any use to you. Neither are new, but both work fine.
With the fan attached, it's 12cm x 12cm x 10cm, and the hose connectors are 9mm ish diameter.
it weighs absolutely sod all, maybe 300g.
At the time I paid about £75 for the lot plus a load of post, it ended up coming from germany or something.
I've done sod all with it for several years, so cross my palms with £45 and I'll post it to your door. I'll listen to offers and swaps for skinny 18" tyres.
If you are interested, PM me as well as posting a reply in here! half the time I don't get PM notifications, and I might not notice a reply in here.
