As title, Mk2 cortina needing welding and paint, depending on taste. Its 1968 so is tax free, is also the original number plate so is transfereable. Has had plenty of welding in the past and body modifications. It has been de locked with a solenoid in the drivers front door. Entry is via the use of an alarm fob type keyring. Also been de bumpered and had the arches flared. All complete and will run (1300 crossflow). Interior all there but carpets and seats out to view welding. Needs repairs to Front valance, drip rails, strut tops, Front top edge of n/s wing, n/s inner wing, n/s a post /panel, bit of n/s front floor, and front of sill, n/s rear inner wheel well and bit of rear sill. Will also need a few bits and pieces patched underneath. It does sound quite bad, but I'm sure that once the bad bits are cut out it wont take long to get done. Also, the bits that don't need doing are pretty good. It does come with a pair of brand new pattern sills and some lengths of made to measure chassis rails.
It does NOT come with the wheels pictured. It will have some steels fitted just so it rolls.
I also have a 2 litre pinto and gearbox for sale separately as well if anyone has the same plans for it that I did!
Its located just ouside norwich and I'm looking for About £500. Localish delivery might be able to be arranged.
