generallee
Nov 18, 2011 10:46:02 GMT
Arc/stick welder £35 Torque wrench £15 Re-chargable LED inspection lamp £10 +loads of other garage-type stuff but I was in a hurry. Not sure I would trust a 15 quid torque wrench to be accurate though...
Nov 18, 2011 10:47:28 GMT
£35 welder....... must be pretty curse word?
Nov 18, 2011 10:50:58 GMT
£35 welder....... must be pretty curse word? an arc welder is very simple, in fact you can make your own pretty easy.
Nov 18, 2011 10:58:47 GMT
hmmmm might invest then, ive only ever welded in uni and college, so I'm not good by any stretch of the immagination. could be good for practicing?
prey
Nov 18, 2011 11:04:50 GMT
i bought one of the led lights the other day - its done about 6 hours so far without charging and is decently bright - doesn't feel the solidest piece of plastic ever though so how well it last remains to be seen - 3yr guarantee though!
bortaf
Nov 18, 2011 12:42:33 GMT
£35 welder....... must be pretty curse word? an arc welder is very simple, in fact you can make your own pretty easy. I used to have a 60's one that consisted of a coil, a few wires with croc clips to go on a car battery and a stick holder, you had to run the car to get it hot enough whilst you welded the same car ;D
R.I.P photobucket
Nov 19, 2011 15:53:04 GMT
Soldering iron kit for £7 in my local aldi store. Thought it was worth adding to the tool collection...
1965 Mk1 Mini 1989 Porsche 911 3.2 Carrera Sport 2004 Audi A2 TDi 2007 Lotus Exige S 2011 Mini Cooper SD
Nov 19, 2011 15:55:02 GMT
I bought a £12 battery charger/conditioner in there not long ago. Not used it but apparently it's pretty good! They have quite a few tools in there sometimes but no idea what they're like...
Nov 19, 2011 18:04:00 GMT
Soldering iron kit for £7 in my local aldi store. Thought it was worth adding to the tool collection... So did I. Until the tip completely melted within 5 minutes use.
picked up one of the lights today.
theres more to life than mpg & to much power is just enough.
