I've got quite a bit to clear out, I've tried to price most of it in accordance with the rules, hopefully common sense will rule with some of the bits (carbs) as it's hard to put an exact price on stuff due to the large quantity I have.
Right first up I've got a fairly nice set of cibie lamps, pair of lamps, although they are both oscars there are small barely noticeable differences between them so probably bought separately. Been in my family for 40 years or so, currently painted in mineral blue. Lenses good, have covers, functioning, reflectors not perfect but pretty good.
Come on a lamp bracket for an MGB but I'm sure will modify to suit most cars.
£75 ono.
Clarke engine stand, not the little flimsy one the bigger more solid version, will take most classic engines no problems. I think it's all there. I'm only after £20 for it I just want rid.
I have lots of MG bits I need to clear out, from B and Midget, if you need anything just ask I'll have a look, however for now I have pairs of window regulators, these seize and break or become loose and slack with use, decent pairs for midget or B (I have both types) £10 a set.
I have a pair of racing bikes (probably of no interest on here) but they are based around a vitus 979 frame with campag gear and a ciocc (one of the italian companies, comparable to colnago or bianchi) with classic shimano gear. Looking for circa £150 and £100 respectively. Vitus alloy frame, ciocc steel frame.
I also have loads of carbs all SU, I mean loads.
I have various 1 1/4 HS2, can probably put some pairs together but would need to have a look, I think generally your best looking as these as bases to recon or for spares though. £5 each
1 1/2 of HS or HIF design, lots of these, singles or pairs. £7 a single or £15 a pair. If I find linkages to suit I will throw them in but they are very cheap to buy from SU Carb/Burlen systems. It's the actual bodies that cost the money. Generally these will be good solid usable carbs needing little or no work to use though.
1 3/4 similar story to HS2, I probably have one or 2 HIF44 but most will be HS6, I doubt I can put good pairs together but could supply a pair of bodies to then make in to a pair. There is no rubbish (sheared screws or badly worn bodies) but likewise expect to recon them. £10 each.
£75 ono.
